What is the Phase Difference between Two Interfering Light Rays?
  • Thread starter Funktimus
    Interference
2 replies · 4K views · last reply
Funktimus
Consider two light rays propagating from point A to point B in the figure, which are 3(lambda)/4 apart. One ray follows a straight path, and the other travels at a 60 degree angle to that path and then reflects off a plane surface to point B. Both rays have wavelength lambda. View Figure
Diagram of a triangular light path: a straight ray from A up to B labeled 3λ/4, and a second ray from A to C on a mirror at right, then C to B, with a 60° angle marked at A.
Find the phase difference between these two rays at point B. Answer in terms of pi.
No equations were provided. But according to my handy textbook:
Phase Difference = 2(pi)(change in x)/(lambda) + change in initial phase
(Phase Difference) = 2(pi)[3lambda/4lambda] + (60 degrees * 2pi/360 degrees)
= 1.83pi
any ideas?
first of all u haven't understood really what phase difference is...
it has nothing to od with angle between the rays...
study some more about phase difference articls on net or yourhandy textbook
so 60 is not initial phase diff
as initial is not given we can take it as zero is uppose
next
change in x is difference in path traveled by the two rays...
here 1 ray travels 3lambda /4
now find the path traveled by the other ray by considering the triangle and laws of reflection
i =r
you will find the triangle to be equilateral
so change in x = 2X 3lambda/4 - 3lambda/4=3lambda/4
now put in your eqn
you will find the ans
i hope no problems...but you got some conceptual probs go figure them out:biggrin:
Thanks for the help. I'll definitely have to look over the inherent phase difference information in my book.
