What is the physical dimension/unit of Probability current?
The physical dimension of Probability Current in quantum mechanics for a particle in one dimension is established as [1/time] or T-1. The discussion clarifies that while the wave function Ψ is often considered dimensionless, its square modulus Ψ*Ψ has dimensions of [length]-1 when integrated over space. The probability current density j is confirmed to have dimensions of [length]-2[time]-1 or L-2T-1, leading to the conclusion that the probability current itself simplifies to T-1.
  • Understanding of quantum mechanics concepts, particularly wave functions.
  • Familiarity with physical dimensions and units of measurement.
  • Knowledge of probability theory as it applies to quantum mechanics.
  • Basic calculus, especially integration over spatial dimensions.
  • Study the derivation of the continuity equation in quantum mechanics.
  • Learn about the implications of wave function normalization in quantum systems.
  • Explore the relationship between probability density and probability current in multi-dimensional quantum mechanics.
  • Investigate the role of action in quantum mechanics and its dimensional analysis.
Students and professionals in physics, particularly those focusing on quantum mechanics, as well as educators seeking to clarify the concept of probability current and its dimensions.
EhrEnFeest
Question:
What is the physical dimension of Probability Current for a particle in 1 dimension? (Quantum Mechanics)
Quantum mechanical Probability Current:
I know the physical dimension of mass, that is kg. If I know every dimension, I can try some things and I can find the dimension of the observable. But now, I'm stuck. I guess that the wave function has no dimension, because it is very related to probability. But what's the case with $$ \frac{\partial \Psi}{\partial x} $$?
Hello Feest, :welcome:
m-1 I would dare to venture ... (on your last question)
But h has dimension of action. Taking Ψ to be dimensionless, j would appear to have dimension of velocity.
Actually ##j## is a probability current density.
Just realized you meant m as metres, not mass. The question is for dimension, so I would answer L-1 there.
But what do you think the dimension of j is, if not LT-1?
With $${\partial \rho\over \partial t} + \nabla\cdot {\bf j} = 0
$$ where ##\rho = \psi^*\psi ## and ##\int \rho \, d\tau = 1##, I would end up with L-2T-1 :smile:
[edit] And now I have to backtrack to 1 dimension as cleary stated in post #1 (o:)) ending up with T-1 :smile:
So here we must react also: It is related to probability in the sense that $$\int \psi^*\psi\,d\tau = 1 $$where the integral is over all space. The ##1## is dimensionless: a genuine probability. So guess again !
This is a nice question to answer. It took me some time but I think:
∫ψ∗ψdτ=1 has no dimensions.
But as you integrate over space, and in this case this is one-dimensional, the dimension of ψ∗ψ is multiplied with [length]. And then ψ has a dimension of [(1/length)^½]?
An unavoidable conclusion, isn't it ? I never worried about the wave function having a dimension (always considered it as dimensionless) and would have liked to keep it that way. But -- unless we are being corrected -- this is what comes out !
So thank you everyone!
Conclusion: the dimension of the probability current is [1/time]?
These physical dimensions used to help me give interpretations to different physical quantities. But in QM, that's not (yet) the case. :)
  • · Replies 25 ·
  • · Replies 25 ·
