What is the potential difference between points A and B in a circuit?
kalupahana
The Cells in a circuit has 2V and 4V emfs and 2Ω and 6Ω internal resistance respectively. Find the potential difference between AB
V=IR
Kirchoff's Laws
The attempts are in image
  • Circuit schematic of two cells in parallel between nodes C, D, A, B, E and F, with a 2V cell and 2Ω resistor in the upper branch and a 4V cell and 6Ω resistor in the lower branch, followed by handwritten Kirchhoff equations: 4v=6I, I=2/3A, -2v=2i, i=-1A, and the note that V=IR is applied to AB.
AB seems to be a shortcircuit. That is a potential difference of 0, so if you end up getting that, it's nothing to worry about. If you got something other than 0, that's when you should be worried. :wink:
Basically, you can think of a shortcircuit as taking a branch with a single resistor R, and doing R → 0. From V = IR, you see that I = V/R, so if R → 0, the only way to stop I from going to infinity and being a defined finite value, is to have V = 0, that is, the potential difference across a shortcircuit vanishes.
If VAB ≠ 0, then it would be I-i that goes to infinity.
The I in my explanation was the I of an arbitrary branch in which a shortcircuit is produced, I didn't use the same circuit as the one given. That's why I said V = IR, and not V = (I-i)R.
The I of my example would be extrapolated to whatever it need be, per particular circuit.
