heusdens
- 1,736
Originally posted by drag
Greetings !
Since the time that they were all based on
physical laws which in turn do not support
the existence of a consciouss - capable
of free and independent thought being.
If you were to truelly think freely then
you can not possibly agree that you still
fully abide the laws of nature at the same
time. According to modern science consciousness
is an illusion and hence purpose is also an
illusion of its dellusional abstract thought.
There has been a time, physics was to be thought as totally deterministic , but modern science has clearly discovered this to be not the case.
Hence your argument fails, and fails only cause you imply wrong conclusions out of physical laws.
Your argument comes down to that the consciousness of human beings, since they are made of the same "stuff" as everything (protons, neutrons, electrons) could not exercise "free will" unless also protons, neutrons and electrons have that property.
This however is a nonsense statement, cause you miss the point that between the layers of atoms and that of a brain, there are many levels of complexity, each with their own properties.
You can not reduce the working of a brain downto atoms.
It doesn't work that way.
The reason these exist and indeed the separation
exists between the original 3 sciences which
I mentioned is the complexity of our Universe.
If we could explain sociology from direct
physical systems using just the laws of
physics then we wouldn't need it at all.
However, the complexity is so great that
this does not appear to be possible at a high
level even within the next few centuries from now.
Like stated before the level of complexity of societal behaviour are not reducible to that of atoms. That is the reason why psychology and sociology are separate disciplines in science. Nevertheless sociology come up with their own set of 'laws' for describing the events in their field of knowledge.
So, since we are not able to make the
connections for now because they are so
complex, we have many sciences each dealing
with different levels and types of patterns
in the Universe. You can also see that the
higher the complexity of the systems a theory
studies the less certain its laws become and
more and more statistics is being used as
the basis of the theory without clear formulated
laws.
There does not, according to modern science,
appear to be any fundumental reason why
these sciences should be separate or independent
besides the complexity issue I mentioned above.
The separation is made only due to compromise
between the usefullness and the practical
ability to make it of a scientiic field as well
as our historical semantic division of the
Universe into the relevant "parts". That's why
it's all called science - all of the observed...
Live long and prosper.
It should be stated that the laws describing reality are ultimately more complex then the large scale behaviour of matter. Even though all properties and laws we can ever witness, are deduced somehow from physical behaviour.
Your argue from the point of total determinism, which is a point of view that has since long be rejected by modern physics.
