What is the Relationship Between Dimensions in Wave Function Calculations?
7 replies · 2K views · last reply
noamriemer
Hello!
There is something I can't understand...
[itex]\psi(0)= \frac {1}{\sqrt 5}|1>+ \frac {2i}{\sqrt 5}|2>[/itex]
I need to find [itex]<H> for \rightarrow \psi(t)[/itex]
For
[itex]E_n= \hbar \omega (n + \frac {1}{2})[/itex] , [itex]\hat {H} =(a^\dagger a+1/2)[/itex]
These make me understand that this problem is one dimensional. (+1/2 in the Hemiltonian)
Finding the time dependence is easy. But now there is a thing I don't understand:
I was told I could relate to the wave function as a vector:
[itex]\psi= \frac {1}{\sqrt 5} \begin{pmatrix}<br /> e^{-it/\hbar}\\ 2ie^{-2it/\hbar} <br /> <br /> \end{pmatrix}[/itex]
And that means :
[itex]|1>=\begin{pmatrix}<br /> 1\\0 <br /> <br /> \end{pmatrix}[/itex]
[itex]|2>=\begin{pmatrix}<br /> 0\\1 <br /> <br /> \end{pmatrix}[/itex]
But now, when I use a on |1> , for instance- I receive |0>.
What does that mean?
I also receive- |3>. according to what I think- I should have defined:
[itex]|0>=\begin{pmatrix}<br /> 1\\0 <br /> \\ 0<br /> \\0 <br /> <br /> \end{pmatrix}[/itex]
, |1>=\begin{pmatrix}
0\\1
\\ 0
\\0
Because I have four base vectors, and should have 4 dimensions. But the problem refers to 1 dim...
What am I not getting here?
How are dimension related?
Thank you!
Thank you!
You can either write a state as:[itex]\psi = c_0 |0\rangle + c_1 |1\rangle + c_2 |2\rangle + c_3 |3\rangle + \cdots[/itex] or simply denote it by its four coefficient and basically making an implicit assumption about the basis states: [itex]\psi = \begin{pmatrix} c_0 \\ c_1 \\ c_2 \\ c_3 \\ \vdots\end{pmatrix}[/itex]
This is the same as when you write a spatial vector, you can either write it as [itex]\boldsymbol{b} = b_x \boldsymbol{\hat{x}} + b_y \boldsymbol{\hat{y}} + b_z \boldsymbol{\hat{z}}[/itex] or just by its component [itex]\boldsymbol{b} = (b_x, b_y, b_z)[/itex]
Presumably, the reason you want to write [itex]\psi[/itex] as a cumbersome column vector is that you are also writing the operators out in matrix form. Try to write out the Hamiltonian [itex]H[/itex]. You will find that it is a diagonal matrix. So when you compute
[tex]\psi(t) = \exp\left(i\frac{t H}{\hbar}\right) \psi(0)[/tex]
The exponential of a diagonal matrix is rather trivial to compute and remains diagonal.
Thank you!
But how do I figure out the dimensions?
What does the length of the vector mean in that context?
My wave function does not include this vector: |7>. But if I use a^dagger- several times I will get it...
Since I have this form of a wave function, doesn't it mean there are two coordinate vectors only? (|1> |2> )
Thank you!
Another thing I am not getting right:
when I want to calculate this:
[itex]<\hat H >=<\psi(t)|\hat H|\psi(t)>[/itex]
I need to do this using these a, a^dagger
But the Hemiltonian is
[itex]\hat H=\hbar \omega (aa^\dagger+1/2)[/itex]
What should I do about the 1/2? add it as a scalar? use it as a 1/2I?
Thank you!
noamriemer said:
Thank you!
In truth, the eigenbasis for H is infinite dimensional, because it contains [itex]|n\rangle[/itex] for all nonnegative integer n.
But the "initial state" of your problem only has two non-zero coefficients: one for [itex]|1\rangle[/itex] and one for [itex]|2\rangle[/itex]. So you don't need to include all those other dimensions if the state evolving in time do not mix with other states.
But this is guaranteed because [itex]|n\rangle[/itex] are eigenstates of the Hamiltonian. They are the called "stationary" state because as the Hamiltonian evolves them in time they do not mix with other states: [itex]|0\rangle[/itex] stays [itex]|0\rangle[/itex], [itex]|1\rangle[/itex] stays [itex]|1\rangle[/itex] etc. The coefficient in front of them can change and find how the coefficient change as function of time is the whole problem!
[itex]\psi[/itex] is not a stationary state because it is combination of [itex]|1\rangle[/itex] and [itex]|2\rangle[/itex], but each [itex]|1\rangle[/itex] and [itex]|2\rangle[/itex] evolves in a stationary fashion.
So your problem has always only been two dimensional
What is the "length" of a vector? You mean like [itex]\boldsymbol{b}\cdot\boldsymbol{b}[/itex]? number of element? The latter is the dimensional of the vector space. The former, in the context of a normalized state, is always 1. Anyway, that was just an analogy that says writing out the coefficient as a column vector is the same as writing in form of a linear combination.
But the point is that your Hamiltonian contains both [itex]a^\dagger[/itex] and [itex]a[/itex] in equal amount. So you actually never get |7>. Refer to the above comment about stationary states don't mix.
Thank you!
Yes!
Thank you!
You have your [itex]a[/itex] and [itex]a^\dagger[/itex] reversed (order is important!)
Just act on the state [itex]|0\rangle, |1\rangle, ...[/itex] with [itex]H[/itex] and see what you get. The 1/2 is just a number that just add to your result of [itex]a^\dagger a[/itex].
Thank you!
The Hemiltonian is given by: [itex]\hat H =\hbar \omega (a^\dagger a +1/2)[/itex]
Isn't it true, that the 1/2 refers to dimensions of the problem? I have seen such thing for harmonic oscillator...
If I apply the Hemiltonian on the wave function, because of the orthogonality of the eigenstates, I get:
[itex]\frac {\hbar \omega} {\sqrt 5} [\sqrt 2 |2> |0> e^{-it/\hbar} +\frac {1} {2} |1> e^{-it/\hbar} +2i\sqrt 6 |3> |1> e^{-2it/\hbar} +i|2> e^{-2it/\hbar}[/itex]
So, regardless to what you said about the wave function collapsing into |1> and |2>, I should always receive only the 1/2 products... all the others should be zero... am I right?
But when I think of it now- if what I wrote is right, there is no meaning to the order of the a operators...Thank you some much for your explanations...
noamriemer said:
Thank you!
You are confusing the dimension of real space with the dimension of the Hilbert Space.
Each spatial dimension essentially acts an independent harmonic oscillators. Your problem is a 1D SHO.
You are confusing acting on a bra on the left side versus acting on a ket on the right side.
[itex]a[/itex] acting on the right (left) annihilates (creates). [itex]a^\dagger[/itex] acting on the right (left) creates (annihilates).
[tex]a |n\rangle = \sqrt{n} |n-1\rangle<br /> \to \langle n| a^\dagger = \langle n-1 | \sqrt{n}[/tex]
[tex]a^\dagger |n\rangle = \sqrt{n+1} |n+1\rangle<br /> \to \langle n| a = \langle n+1 | \sqrt{n+1}[/tex]
Also when you do something like [itex]\langle \psi | H | \psi\rangle[/itex], you should just get a number. Not some convoluted ket times ket like you have up there, which really has no meaning.
Ok... but if I want to calculate [itex]<1|a^\dagger a+1/2|1>[/itex]
I do it this way:
[itex]<1|[\sqrt 1 \sqrt 2 |0> |2> +1/2 |1>][/itex]
and, when I apply the left part, I then receive:
[itex]\sqrt 2 <1| |0> |2> + 1/2 <1||1>[/itex]
The first term vanishes, and only the second remains, giving 1/2I (I is the unit matrix)
Thank you for your time and patience. You could probably tell- English is not my mother-tongue... so my questions\answers might seem a bit vague...
[tex]\langle 1 | a^\dagger a + \frac12 | 1 \rangle<br /> = \langle 1 | a^\dagger a | 1 \rangle + \frac12 \langle 1 | 1 \rangle[/tex]
The second term is just 1/2. The first term is:
[tex]\langle 1 | a^\dagger a | 1 \rangle<br /> = \langle 1 | a^\dagger | 0 \rangle<br /> = \langle 1 | 1 \rangle = 1[/tex]
Notice how there is always 1 bra and 1 ket throughout. Never 2 ket like what you did.
