Engineering What is the Relationship Between Resistor Values in an Attenuator Circuit?
  • Thread starter Thread starter profbuxton
    Resistor
The discussion revolves around solving for resistor values R1 and R2 in an attenuator circuit, given a specific equation for R0. The user is struggling to manipulate the equations to find a solution, noting that there are three unknowns but only two equations available. Participants suggest expressing R1 and R2 in terms of R0 to simplify the problem. They provide equations to rearrange and manipulate, including a specific equation for R0 set at 60. The conversation emphasizes the need for algebraic manipulation and quadratic solving techniques to arrive at the correct resistor values.
profbuxton
Find R1 and R2
(R1+R2 +Ro) /R2 = 5 where Ro = SQRT(R1 x R2+(R1 x R1) / 4) = 60
Greetings, fellow travelers.
I gave been digging into some of my old (1970s) Electronic maths textbooks and for my amusement and time wasting refreshing some old knowledge. Have got through a fair but but have to keep coming back to this problem.
I do have the answers but I cannot regardless of how I manipulate the variables I can't seem to find the correct method obtain the answer. This problem is in part of the book related to solving quadratics but I can't see how this is related. Any broad hints at a solution would help me sleep better. Thanks for your assistance.
PS sorry about the format of the equations. Havent used the system to enter equations before. Maybe I will learn that too!
Greetings too.
What's the complete problem statement ? Any diagrams ?
sorry no diagrams with this problem.
The problem is to find the values of R1 and R2. I have tried manipulating the known answers to find the correct algorithm(big word that) but cannot find the correct method. I suspect it turns into some kind of quadratic but its been so long ago since I played with this stuff.
EDIT. Sorry - didn't spot that the value of R₀ is given. The reply (below) is therefore not relevant. See Post #6 instead.
There are three unknowns (R₀, R₁ and R₂) but only two equations. So you can’t solve for the values of R₁ and R₂.
Maybe you are meant to express R₁ and R₂ in terms of R₀. For example:
R₁ = 2.5 R₀ and R₂ = 0.2R₀
(not the answers, just some random made-up numbers for illustration).
If this is the case let R₁ = aR₀ and R₂ = bR₀. The problem is then to find a and b.
Substitute for R₁ (replace it by aR₀) and for R₂ (replace it by bR₀) in your equations.
You will get two equations containing only a and b. See if you can solve these.
Oh, sorry for the misunderstanding. The value for Ro is given by the equation
Ro = SQRT(R1 x R2+(R1 x R1) / 4) = 60 so in the first eqn. Ro actually equals 60.
sorry if it wasnt too clear . my bad. does that help?
Whoops – my mistake. Sorry. See if this gets you started...
Replace R₀ by 60 and you get two equations:
(R₁+ R₂ + 60) / R₂ = 5 (equation 1)
√(R₁R₂ + R₁²/4) = 60 (equation 2)
Rearrange equation 1 to make R₁ the subject.
Square both sides of equation 2 to get a new equation without the square root.
Can you take it from there?
If you need a reminder on how to solve quadratic equations, see here for example: https://www.bbc.co.uk/bitesize/guides/zwmyxfr/revision/1
In LaTeX:
$$R_0 = \sqrt{R_1 R_2 + \frac{R_1^2}{4}}$$
See the LaTeX Guide link below the Edit window. :smile:
