What is the Relationship Between Speed of Light and Time?
The discussion revolves around the relationship between the speed of light and the concept of time, particularly in the context of time dilation as described by Einstein's theory of relativity. Participants explore how time behaves differently for observers in relative motion, using thought experiments and examples to illustrate their points.
  • Some participants explain that according to Einstein's theory, as objects approach the speed of light, they gain mass and require increasingly larger amounts of energy to accelerate further.
  • One participant describes a thought experiment involving atomic clocks to illustrate time dilation, noting that a clock on a jet traveling at 600 mph showed a slight time difference compared to a stationary clock.
  • Another participant emphasizes that time dilation is perceived differently by observers in relative motion, where each sees the other's clock as running slower.
  • A participant presents a scenario involving twins, where one travels at near-light speed and returns younger than the twin who remained on Earth, raising questions about the nature of time and aging.
  • Disagreement arises regarding the perception of time between two observers, with one participant asserting that a stationary observer would see the moving observer's clock running faster, which is contested by others.
  • Some participants argue that the effects of time dilation are due to the relative motion and acceleration of the observers, rather than simply their constant velocities.
  • Another participant explains that the speed of light remains constant in all inertial frames, which leads to different observations of light pulses by moving and stationary observers.
Participants express multiple competing views regarding the perception of time between moving and stationary observers, and the discussion remains unresolved with no consensus on certain aspects of time dilation and its implications.
Participants reference specific thought experiments and examples, but there are unresolved assumptions about the nature of time and the effects of acceleration versus constant velocity on time perception.
dannyPhysics
How time Travel work ?
ok i know some of the basic about speed of light...
You can't get to the speed of light ...
You can't reach the speed of light cause According to Einstein's special theory of relativity, and E= MC ^2 objects gain mass as they accelerate to greater and greater speeds. Now, to get an object to move faster, you need to give it some sort of push. An object that has more mass needs a bigger push than an object with less mass. If an object reached the speed of light, it would have an infinite amount of mass and need an infinite amount of push, or acceleration, to keep it moving. No rocket engine, no matter how powerful, could do this. In fact, as far as we know, nothing can exceed the speed of light.
And i know how it work
Imagine you're standing on Earth holding a clock. Your friend is in a rocket zooming past you at nearly 186,000 miles per second. Your friend is also holding a clock. If you could see your friend's clock, you'd notice that it seems to be moving a lot more slowly than yours. Your friend, on the other hand, thinks the clock in the rocket is moving just fine, while your clock on the ground seems to be moving very fast. Test it out ?
Atomic clocks are extremely accurate clocks that can measure tiny amounts of time—billionths of a second. In 1971, scientists used these clocks to test Einstein's ideas. One atomic clock was set up on the ground, while another was sent around the world on a jet traveling at 600 mph. At the start, both clocks showed exactly the same time.
What happened when the clock flown around the world returned to the spot where the other clock was? As Einstein had predicted in a general way, the clocks no longer showed the same time—the clock on the jet was behind by a few billionths of a second. Why such a small difference? Well, 600 mph is fast but still just the tiniest fraction of the speed of light. To see any significant differences in time, you'd have to be traveling many millions of miles an hour faster. If you are moving time will slow down, even you in Earth or out of space
but my big big question is, how Speed of light (C) or speed have anything to do with time ? what is time ? i mean How time slow down ?? How time can slow down when travel ?hope u guy can explain for me
Slow. Not fast. You think your friend's clock is moving slowly, and your friend thinks your clock is moving slowly. (Weird, I know. But that's the only way to be consistent - it could just as well be you moving and your friend who is at rest.)
dannyPhysics said:
Test it out ?
Hmmm... that's kind of like asking "why is relativity true." Because people did the experiments and found that it is. Other than that, you're getting into the territory of philosophy.
It might be a little misleading for you to think about it as time slowing down; in a sense, time dilation (the effect you're talking about) is a transformation that happens when you change velocities. Things happening at a velocity different from yours always seem slower than they would if you were traveling along with them. Mathematically, it's a shear effect, a "hyperbolic rotation" (one could say), and it makes sense if you accept the math, but if you're not already at least somewhat familiar with that (the math) it probably wouldn't do you much good to see that explanation in detail.
NO like i say my friend stay on earth, will see my clock (if he can ) going faster
and i will see his clock (if i can) going slower than normal
i know that, when a person travel his time is not slowing down, but relate to other people who at rest, his time is slow than the people who at rest
like this story:
Al's parents decide to send him to summer camp in the Alpha-3 star system, which is 25 light-years away (a light-year is the distance light travels in a year). Bert doesn't want to go and stays home on Earth. So Al sets out on his own. Wanting him to get there as quickly as possible, his parents pay extra and send him at 99.99 percent the speed of light.
The trip to the star and back takes 50 years. What happens when Al returns? His twin brother is now 60 years old, but Al is only 10 and a half. How can this be? Al was away for 50 years but only aged by half a year. Has Al just discovered the fountain of youth?
Not at all. Al's trip into space lasted only a half year for him, but on Earth 50 years passed. Does this mean that Al can live forever? Nope. He may have aged by only half a year in the time it took 50 years to pass on Earth, but he also only lived half a year. And since time can slow down but never goes backwards, there's no way he could grow younger.
But my question is how it work? why?
NO your friend will see your clock moving slower than his and you will see your friend's clock moving slower than yours. I don't know where you're getting the information that your friend will see your clock moving faster than his, but it is absolutely wrong. (Assuming that both you and your friend correct for the Doppler shift, of course)
dannyPhysics: diazona is not wrong. Your friend flying past the Earth is the equivalent of your friend at rest in space while the Earth "flies past him". They are equivalent. Replace the Earth with another spaceship and you will see.
The time differential actually occurs from the acceleration/deceleration of your friend in space. In other words, he accelerates to fly by, then he must decelerate to stop and turn around to come back to Earth so that you may compare clocks. This is different from "just moving by another object quickly".
^^ thank but u guy not answer my question ^^
The speed of light is the same in every inertial frame. So let's say we have two observes one flying in a spaceship the other stationary on earth. The spaceship fires a light pulse, what do the observes see? The observer on Earth will see the pulse of light travel at c, not c+v_spaceship. The observer in the spaceship will also see the pulse travel away from him with speed c. For this to add up, time has to be dilated and space has to be contracted.
Your questions have been answered but you refuse to accept them! What reason do you have to keep saying "NO"? If you believe you already know the answers, why did you ask?
The fact that you titled this "How time Travel work?" but asked questions that have nothing to do with "time travel" (answer: it doesn't work!) suggests to me that you are not clear on what questions you want to ask.
dannyPhysics: Are you asking WHY time dilation occurs at all, or simply why does time dilation occur as it relates to the speed of light? Relativity DESCRIBES reality but it does not EXPLAIN it, unfortunately.
I have a couple of personal theories on why time dilation occurs, but they are not even half-baked at this point so I won't be subjecting them to forum criticism just yet. :)
No-one can really explain to you the nature of time, but they can discribe our observations of time in our experineces, because of mathamatics based on the constancy of light. It makes sense, both logically and mathamatically, and while proving the constancy of light is a difficult feat, all experimental data regarding time dilation helps prove the correctness of Einstein's theory.
Slow down. This,
Your friend is in a rocket zooming past you at nearly 186,000 miles per second. Your friend is also holding a clock. If you could see your friend's clock, you'd notice that it seems to be moving a lot more slowly than yours. Your friend, on the other hand, thinks the clock in the rocket is moving just fine, while your clock on the ground seems to be moving very fast,
is not true.
This scenario compares only two clocks in relative motion. This is not the usual experiment. Instead you have substituted two clocks in relative motion. The observations are symmetric in your scenario. An approching clock appears to be running faster. A receding clock appears to be running slower.
"Einstein began his analysis ... by giving operational definitions ... consistent with the principle of relativity and with the validity of Maxwell's equations ... [emphasis mine]" http://books.google.com/books?id=ggPXQAeeRLgC&printsec=frontcover#PPA58,M1
here I thought I was going to see someones plans for a flux capacitor, darn!
well this just simply a consequence of relativity, a phenomenon, only God knows what time is and why velocity affects it.
dannyPhysics said:
right here: http://www.pbs.org/wgbh/nova/einstein/hotsciencetwin/ >> u want to go againt it ?? u wrong
No, the web page is wrong. Otherwise I'm sure someone would have pointed it out on this thread.
Thanks for pointing out the site, though, I think I'm going to call their attention to it...
Good grief. who on this thread has been right about anything. I see misinterpretation on misinterpretation. Where's the reset button?
  • · Replies 26 ·
  • · Replies 51 ·
  • · Replies 25 ·
