What Is the Required Distance for Young's Double-Slit Experiment?
  • Thread starter Thread starter Kris1120
    Experiment Split
The discussion revolves around Young's double-slit experiment, specifically focusing on calculating the distance from the slits to a screen based on given parameters such as wavelength, slit spacing, and the spacing between dark fringes.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants explore various equations related to interference patterns, questioning the appropriate formulas for dark fringes and the use of the small angle approximation.
Participants are actively engaging with the problem, with some providing guidance on the correct equations to use. There is a recognition of the need to clarify the distinction between different orders of dark fringes and how to apply the equations accordingly. Multiple interpretations of the problem are being explored.
There is a mention of confusion regarding the correct value of 'm' for the dark fringes and the need to consider the distance between fringes rather than from a central point. Some participants express difficulty in locating relevant formulas.
Kris1120
Light of wavelength 473 nm falls on two
slits spaced 0.389 mm apart.
What is the required distance from the slit
to a screen if the spacing between the first and
second dark fringes is to be 6.71 mm?
Answer in units of m.
sin\theta= m\lambda/d
x=tan\theta*L
\theta = sin-1{2*473e-9m / .389e-3 m} = .139336 degrees
L = 6.71e-3 m / tan .139336 = 2.75919
Hi Kris1120,
I don't believe this is the formula you want. They are referring to the dark fringes in this problem.
Also, when you solve for the distance remember they want the distance between two fringes, not the distance from one fringe to the center point.
Ok so I am using the equation sin(theta) = (m +.5) lambda / d ... Does that mean I do not use the equation to solve for x?
You do still have to solve for x.
However, I think here you should use the small angle approximation that combines both equations (because for small enough angles sin(theta)=tan(theta)). Does your book have that formula?
No. I can't find it
Kris1120 said:
No. I can't find it
For constructive interference, you have the two equations that you had in your original post:
<br /> \sin\theta= \frac{m\lambda}{d}<br />
<br /> \tan\theta= \frac{x}{L}<br />
For small angles,
<br /> \frac{x}{L} =\frac{m\lambda}{d}<br />
so you can find the distance along the screen x directly for each line order (again, when the angles are small). You can do the same thing with the destructive interference case, and get the same equation with m \to (m+1/2).
If I am not misunderstanding... I set the sin equation equal to the tan equation and solve for L... I am still not getting it correct though. I am trying to look the equation up on google.
Maybe I am using the wrong m... m=2?
The formula that I mentioned for the destructive interference:
<br /> x = L \frac{(m+\frac{1}{2} )\lambda}{d}<br />
gives the x value for each fringe. What they tell you in the problem is that the difference in the x values is 6.71mm. Do you see what to do?
I just saw your last post. The first order dark fringe would have m=0, and the second order dark fringe would have m=1, based on how you wrote your destructive interference condition.
6.71 mm = [L((1+.5) * 473 nm)/ .389 mm] - [L((0+.5)*473nm)/ .389 mm] and solve for L? I get L = 5.51809 m is that correct?
That looks right to me.
Great! Thank you for being so patient with me.
I'm glad to help!
11K
