What is the residue of exp(1/z) at z=0?
  • Context: Graduate
  • Thread starter Thread starter DrKareem
    Function Residue
The residue of the function \(\exp{\frac{1}{z}}\) at \(z=0\) is not applicable as \(z=0\) is classified as an essential singularity rather than a pole. The Laurent series expansion confirms that the function includes all negative integer powers of \(z\), indicating the absence of a finite-order pole. Therefore, the residue, which is defined only for poles of finite order, cannot be determined in this case. The discussion highlights the importance of correctly identifying singularities in complex analysis.
  • Understanding of complex analysis concepts, specifically singularities and poles.
  • Familiarity with Laurent series expansions.
  • Knowledge of residue theory in complex functions.
  • Experience with analytic functions and their properties.
  • Study the properties of essential singularities in complex analysis.
  • Learn about the application of Laurent series in determining residues.
  • Explore different methods for analyzing singularities in complex functions.
  • Investigate the implications of residues in contour integration.
Students and professionals in mathematics, particularly those studying complex analysis, as well as anyone involved in advanced calculus or theoretical physics who seeks to deepen their understanding of singularities and residue calculations.
DrKareem
Hi. I'm trying to find the residue of
\exp{\frac{1}{z}}
at z=0 since it is a pole, so I can integrate the function over the unit circle counterclockwise. I expanded this function in Laurent Series to get
\exp{\frac{1}{z}} = 1 + \frac{1}{1!z} + \frac{1}{2!z^2}+ ...
So in this case the residue is the coefficient of 1/z which is 1. Is this method correct? There is no answer to it in the book...
EDIT: If you guys can find the residue using another method, please teach me.
EDIT 2: Fixed the typo :p
Perfect, except you need z^(-2) in the 3rd term above (i'm sure you made a typo).
Oh yes it is a typo. Thanks for the input.
Except that z= 0 is NOT a pole for e1/z. A point is a "pole of order n" for function f(z) is znf(z) is analytic but no zkf(z) is analytic for k< n. In particular, the Laurent series for f(z) has no power of z less than -n. Since the Laurent series for e1/z has all negative integers as powers, z= 0 is an essential singularity, not a pole.
It's been a couple years since I took complex analysis, but yes, this seems like a perfectly accurate way to find the Laurent Series (and by consequence the residue as well).
Halls is correct. The residue is defined only for a pole of finite order, which you do not have.
Thank you HallsofIvy for clarifying this matter. This must be the reason why the other methods for finding the residue are not applicable, just like what Deadwolfe suggested. That explains a lot. And thanks for the rest for your input.
