What Is the Resultant Force Exerted by a Car on the Road?
The discussion revolves around determining the resultant force exerted by a car on the road while it is pulling a trailer. The problem involves concepts from dynamics, specifically Newton's second law of motion, and requires consideration of forces acting on the car and trailer system.
  • Participants discuss the forces acting on the car, including the forward force from the ground and the backward force from the trailer. There is confusion regarding the calculation of the resultant force and its direction.
Participants are actively exploring the relationships between the forces involved. Some have attempted calculations but express uncertainty about their results. There is a suggestion to create a drawing to clarify the situation, and participants are questioning the correlation between the resultant force and its direction.
There is mention of ignoring frictional forces and the need to clarify the direction of the resultant force. Some participants are unsure about the definitions and relationships between the forces involved, particularly in relation to the normal force and the force exerted by the road on the car.
jelly1500
[SOLVED] Resultant force on a car
A 1070 kg car is pulling a 320 kg trailer. Together the car and trailer move forward with an acceleration of 2.01 m/s2. Ignore any frictional force of air drag on the car and all frictional forces on the trailer. Determine the following.
(a) the net force on the car
(b) the net force on the trailer
(c) the force exerted by the trailer on the car
(d) the resultant force exerted by the car on the road
(e) direction (measured from the left of vertically downwards)
F=ma
I figured out A, B & C but can't seem to get D & E. I thought the resultant force exerted by the car on the road is Fg=mg=1070(9.8)=10486 but it is wrong.
And for the direction, I used inverse tan (10486/2150.7) but that was wrong too. (2150.7 being the net force on the car)
The car is experiencing a forwards directing force, let's say F, from the ground and a backwards directed force coming from the trailer, let's say T. These two forces combined gives the resultant force that the car is experiencing.
So would the forwards directing force be F=2150.7 (from answer a) and the backwards directed force coming from the trailer be T=643.2 (answer b), giving me a total resultant force of 2793.9.
Sorry I'm still a confused.
Correct. Best make a drawing. That may crystalize the situation for you. What it means is that the force coming from the ground need to supply the resultant force accelerating the car and the trailer.
Ok, thank you so much.
And for part e, I would then get the inverse tan of 10486/2793.9?
10486 being the force of gravity in the y direction and 2793.9 being the resultant force in the x direction.
The direction of which force is required - it is not clear for me from the question as you put it?
Oh sorry for not making that clear: D and E are correlated, so the direction of the resultant force exerted by the car on the road.
I assume that it is the force from the road on the car. According to my drawing it looks like the tangent is the forward force divided by the normal force.
oh ok, thank you for all your help!
I assume you mean the resultant force from the road on the car?
In that case my drawing shows that the tangent is given by the ratio F/N , N being the normal force acting on the car.
17K
