What is the resulting intensity maximum at a minimum?
  • Thread starter Thread starter xago
    Intensity
1 reply · 3K views · last reply
xago
Surprisingly, large interference effects can occur even when one of the interfering sources is
not very probable. In the two-slit interference experiment, if one slit is “stopped down” so that
the intensity of the wave getting through is reduced by a factor of 100 (relative to the other
slit), show that the intensity maximum of the pattern is still (roughly) 50 per cent higher than
at a minimum.
[tex]\psi[/tex]2 = A*ei(kr1 - wt)
[tex]\psi[/tex]1 = A*ei(kr2 - wt)
I'm assuming that we add the 2 wave equations to find [tex]\psi[/tex]total.
Since 1 slit has 1/100 the intensity of the other and since I is proportional to A2
then the amplitude of reduced-intensity wave would have A= 1/10000?
This assumption still works well for double-slit interference experiment :smile:
You should check your calculation. Areduced = A/sqrt(100).
