What is the Shear Stress in Bolts for a Given Torque and Separation Distance?
7 replies · 3K views
Matthew Heywood
I've solved everything up to part d). I generally struggle with questions on bolts and I'm really not sure how to tackle this problem.
τ = Tr/J, τ = 200MPa, T=1kNm
I worked out the separation of the bolts (I think).
Circumference around the inside: 2π(25mm) = 0.157m ∴ Separation: 0.157/2 = 0.0785m
Not sure where to go next, if I'm honest. I tried this:
T = 1kNm ⇒ F = 1kNm/0.0785m = 12.7kN
so σ = F/2A as double shear so A = F/2σ = 12.7kN/2(200MPa) = 3.19x10-5m2
so πr2 = 3.19-5 ⇒ r = 3.18mm ⇒ d = 6.37mm
so I went wrong somewhere as the answer is 11.28mm
any help appreciated. Thanks
It's not clear how the circumference of the solid shaft is useful here. You were instructed by the problem statement that friction between the shaft surface and the coupling was to be neglected. Therefore, all of the torque transmitted to the solid shaft must be resisted by the two bolts. What force on the bolts would produce an equal torque?
This approach is not correct for the reason given above.
Ah okay. So the for the force on each bolt:
T = Fm ⇒ F = 1kNm/50mm = 20kN
So 10kN on each bolt?
You might want to check that figure of 10 kN/bolt.
Oh okay. So would it be 20kN?
Yes.
so A = 20kN/200Mpa = 1x10-4
then r = √(1x10-4/π) = 5.64mm
so d = 11.3mm
Thanks :D
