What is the significance of calculating the average value of cos?
The average value of cos(theta) for molecules in kinetic theory is calculated to be 2/3, which is significant in understanding molecular behavior upon collision with surfaces. This average is derived from the range of angles theta, specifically from 0 to pi/2, where theta is measured with respect to the normal of the wall. The calculation of this average value is crucial as it helps in predicting the distribution of molecular impacts on surfaces, thereby influencing theoretical models in physics.
  • Understanding of kinetic theory and molecular dynamics
  • Familiarity with trigonometric functions, specifically cos(theta)
  • Knowledge of integration within specified limits (0 to pi/2)
  • Basic principles of collision theory in physics
  • Research the derivation of average values in trigonometric functions
  • Explore the implications of average molecular speeds in kinetic theory
  • Study the role of angle measurements in collision theory
  • Investigate the impact of surface interactions on molecular behavior
Students and professionals in physics, particularly those focusing on kinetic theory, molecular dynamics, and collision analysis, will benefit from this discussion.
srhelfrich
In kinetic theory, the number of molecules hitting a unit area of a surface per unit time with speeds between v and v + dv and angles between \theta and \theta + d \theta is found to be a function of sin(theta) and cos(theta). There will often be a practice problem asking to show that the average value of cos(theta) for these molecules is 2/3.
My question is why the expected value wouldn't be zero instead of 2/3? What is the significance of finding this average value?
Check the average value of |cos(θ)|.
What is the range of values of θ? Are you considering molecules that hit one side or both sides of the wall?
I understand that it works out mathematically. I also figured out that theta is measured with respect to the normal of the wall so now I see why it shouldn't be zero.
But what is the significance of finding the average value? Why is this something we would be interested in calculating?
Yeah, I just realized the range is from 0 to pi/2. The angle is measured wrt the normal of the wall.
Sure, the math works.
But why is it significant?
What about molecules coming in from one side of the normal, versus coming in from the other side of the normal?
  • · Replies 18 ·
