What is the solution for x in the infinite exponent tower x^x^x^...=2?
  • Thread starter Thread starter The Divine Zephyr
    Exponent Infinite
The problem involves solving the equation for x in the context of an infinite exponent tower, specifically x^{x^{x^{...}}} = 2. This falls under the subject area of mathematical analysis and exponentiation, particularly focusing on the behavior of infinite sequences and limits.
  • Participants explore various values for x, such as 1 and \sqrt{2}, and discuss their implications on the convergence of the infinite exponent tower. Some participants question the assumptions made regarding convergence and divergence, particularly for values greater than 1.
The discussion includes multiple interpretations of the problem, with some participants suggesting that \sqrt{2} may be a solution while others argue that it diverges. There is an ongoing exploration of the conditions under which the infinite exponent tower converges or diverges, and some participants have offered insights into the nature of the sequence.
Participants note that the problem could be interesting to consider in the context of complex numbers, and there are references to the limitations of calculators in evaluating such expressions. The discussion also highlights the importance of distinguishing between different forms of exponentiation in the context of the problem.
The Divine Zephyr
Infinite Exponent "towers"
Please help me solve this problem; I don't even know how to start...
Solve for x: [tex]x^{x^{x^{x^{...}}}}=2[/tex]
if x=1, x^x^x^x... =1
if x >1, x^x^x^x... = infinity
so x is undefine
so x is undefine
You can say that the equation does not admit a real solution...
Daniel.
P.S.The problem would be interesting to consider and solve in [itex]\mathbb{C}[/itex]... :wink:
Daniel.
Teteration
Solve for x: [tex]((((((x^x)^x)^x)^x)^x)^ ...)=2[/tex]
LaTeX can't seem to stack exponents, like they should be
(x^x^x^x^x^x^x^x^x^x^x^x^...)
Let the iterated exponent (a teteration) be called LHS (left hand side)
Then LHS=y=2
but the iterated exponent is also equal to LHS so that:
LHS^y=2
but y=2
so that:
x^2=2
or:
x=Sqrt[2]
Yea, I know it's hard to grasp. I need to work on it too.
SD
so x is undefine
So far, I got that
if x=1, my LHS=1
if 0<x<1, LHS converges to 1
if x>1, LHS diverges
Then LHS=y=2
LHS^y=2
but y=2
so that:
x^2=2
or:
x=Sqrt[2]
I plugged it in on a calculator and it divirged into infinity...
Go for it, I'll think about that, too.
saltydog said:
x=Sqrt[2]
Try to see whether it verifies the equation...
Daniel.
It doesn't, [tex]\sqrt{2}^{\sqrt{2}^{\sqrt{2}}}[/tex] does infact come very close to 2 (I think exactly, don't have my 89 with me...), however. But as soon as more terms are piled on, it spirals into infinity.
if x<1, LHS converges to 1
This is obvious for the expression [tex]((x^x)^x)^x...[/tex]
but how did you show convergence for
[tex]x^{x^{x^{x^\cdots}}}[/tex]
For the first, you get the sequence 2^{-1}, 2^{-1/2}, 2^{-1/4},...,2^{-1/2^i} but for the second the form gets ugly:
2^{-1}, 2^{-1/2}, {sqrt{2}/2}^sqrt{2}, {1/2}^{{sqrt{2}/2}^sqrt{2}}, ...
My forays with Windows calculator are giving me oscillations, so I can't be sure it doesn't converge to something less than 1.
I'm sorry, the correct expression for me would have been 0<x<1 will converge to 1
2^{-1} is less than 1. :) But I'm not sure the power tower sequence it generates converges to 1, as I can't find a general ith term for the sequence.
SQRT [2] IS THE CORRECT ANSWER...
Generally
[tex]x^{x^{x^{x^{...}}}}=a[/tex]
Has the solution
[tex]x=a^{\frac{1}{a}}[/tex]
Iteration & logarithmation to show it...
Daniel.
I see where you are coming from, but I can't see it working the the equation...
SQRT [2]^SQRT [2]^SQRT [2]=2, but as soon as more SQRT [2]s are stacked, it flies off the mark...
No,it doesn't,trust me...Do you approximate results (intermediary) ??If so,then that's why it may jump over 2...
Daniel.
Hmm. Mathworld has an expression for the general solution of the infinite power tower at http://mathworld.wolfram.com/PowerTower.html , but its not as simple as a^{1/a}. However, the equation seems to verify that the power tower of sqrt(2) converges to 2.
Regarding dex, it's true. sqrt(2) is an irrational number so it can't be rationed about like a finite decimal on a calculator. :)
I idnt approximate. I got 2 for a stack of 3 sqrt twos, but as I did [tex]x^{x^{x^{x^{...}}}}[/tex], it went to infinity.
[tex]\log_{x}2=x^{x^{x^{x^{...}}}}[/tex]
Can you show me how your solution was attained?
I see the link, I'll go check it out.
dextercioby:
are you having a bad day?? ...I'll show you if x=2^1/2, then x^x^x^x >2,
let x=2^1/2
x^x^x^x=x^(x*x*x) = x^(2*x) = 2^(1/2*2)^x = 2^x >2
vincent: a^a^a^a means
[tex] a^{a^{a^{a}}}[/tex]
not
[tex] (((a^a)^a)^a)^a[/tex]
Or, written flatly, it's x^x^x^x := x^(x^(x^x)))
vincentchan said:
dextercioby:
let x=2^1/2
x^x^x^x=x^(x*x*x)
This step is wrong. We're finding the result of x^(x^(x^...)), not ((x^x)^x)^...
Ie., (sqrt(2)^sqrt(2))^sqrt(2) = sqrt(2)^(sqrt(2)*sqrt(2)) = sqrt(2)^2 = 2,
but there is no similar way to simplify sqrt(2)^(sqrt(2)^sqrt(2)).
so the expression is:
x^(x^(x^(x^(x...)??
i was keep doing
x^x^x^x^x...
idoit me
for your [tex] a^{a^{a^{a}}}[/tex]
it really depend on how ppls read...
Anyways,the problem asked for the solution of the equation.Not for divagation regarding "power tower"...
Vincentchan,are YOU having a bad day??
Daniel.
[tex]\sqrt{2}[/tex] is obviously incorrect. It diverges, just like all x>1. I'm guessing you arrived at that answer by something like this:
[tex]x^{x^{x^{x...}}} = 2[/tex]
[tex]x^{x^{x^{x...}}} = x^2[/tex]
[tex]x^2 = 2[/tex]
[tex]x = \sqrt{2}[/tex]
The problem is that you are assuming [tex]\infty=\infty[/tex] (since the power tower diverges), and this isn't always true. By the same logic, I could say:
[tex]s = 1 + 2 + 4 + 8 + ...[/tex]
[tex]2s = 2 + 4 + 8 + ... = s - 1[/tex]
[tex]s = -1[/tex]
[tex]x^2 = 2[/tex]
The problem is that you are assuming [tex]\infty=\infty[/tex], since the power tower diverges, and this isn't always true.By the same logic, I could say:
[tex]s = -1[/tex]
YOU ARE TERRIBLY WRONG!
Please,do not GUESS WHAT I AM THINKING... :devil:
THIS EQUATION HAS THE SOLUTION i specified in the post with lots of red...
Daniel.
It's fairly easy to prove the sequence [itex]\sqrt{2} \uparrow \uparrow n[/itex] converges as [itex]n \rightarrow \infty[/itex]: it's a bounded, monotone sequence.
Careful how you plug this into your calculator...
Are you calculating:
Or are you calculating
[tex](((x^x)^x)^x)^x...[/tex]
The first one goes to 2 if x=sqrt(2). The second one does not.
The way to plug it into the calculator is like this:
[tex]a_0=\sqrt{2}^\sqrt{2}[/tex]
[tex]a_1=\sqrt{2}^{(a_0)}[/tex]
[tex]a_2=\sqrt{2}^{(a_1)}[/tex]
etc...
youre right, I'm wrong (those big letters are annoying, though). It seems like it would diverge for x>1, but it's only for x>e^(1/e). Which lead to the interesting paradox that x goes to 1 as a goes to infinity, and yet for x=1, a=1.
They were meant to be annoying,not for the fact that u contradicted me when you were wrong,and i was right,but for doing that by assuming what i was thinking... :rolleyes:
Daniel.
Proof for convergence
Would anyone be willing to provide a reasonably short (if possible) proof for the convergence interval for the function? Or perhaps someone can cite an on-line reference for the proof. If I obtain one I can understand, I'll post it.
Thanks,
SD
The solution to the equation
[tex]x \upuparrows \infty = a[/tex]
is [tex]a^{\frac{1}{a}}[/tex]
,which is never bigger than [tex]e^{\frac{1}{e}}[/tex]
Daniel.
Daniel.
Thanks Daniel,
However, my understanding is that the hyperexponent function above converges only when x is in some interval. Can you please tell me how to incorporate math symbols into my posting so I can be more specific? I have Mathematica. Can I export data from there?
Thanks,
SD
