What is the Solution to a Population Growth Differential Equation?
The discussion revolves around a differential equation modeling population growth, specifically examining the rate of change of a population \( P \) based on birth and death rates. The equation presented is \( \frac{dP}{dt} = bP - dP \), with specific values for \( b \) and \( d \) provided, alongside an initial condition for \( P(0) \).
  • Mixed
  • Participants explore the manipulation of the differential equation, including attempts to apply partial fractions and integration techniques. There are questions about the correct application of terms and the integration process, particularly regarding substitutions and the handling of constants.
The discussion is ongoing, with participants providing guidance on integration techniques and clarifying misunderstandings about the setup of the equation. There is a focus on ensuring proper notation and the correct application of mathematical principles, although no consensus has been reached on the final solution.
Participants express confusion over specific integration steps and the use of notation, indicating a potential gap in foundational knowledge regarding integration by substitution. The original poster's attempts and the responses highlight a collaborative effort to clarify these concepts.
cheddacheeze
Consider a population whose number we denote by [tex]P[/tex] . Suppose that [tex]b[/tex] is the average number of births per capita per year and[tex]d[/tex] is the average number of deaths per capita per year. Then the rate of change of the population is given by the following differential equation,
[tex]dP/dt = bP-dP[/tex] where t is in years
[tex]d = 4 + P/200, b = 9 and P(0) = 200[/tex]
solve for [tex]P(t)[/tex]
(Hint: you might find the partial fraction in part (c) useful in determining your solution.)
part (c) being:
[tex]200/P(1000-P) = A/P + B/1000-P[/tex]
A=1/5, B=1/5
[tex]dP/dt = 9P-(4+P/200)[/tex]
[tex]dP/dt = 9P-4-P/200[/tex]
[tex]dP=(9P-4-P/200)dt[/tex]
[tex]dp/(9P-4-P/200)=dt[/tex]
im thinking the partial fraction comes somewhere in between my 3rd and 4th line but i can't seem to think what factor and exactly where...
From your data [itex]bP-dP=9P-(4+P/200)P[/itex]. You're missing that last P in your attempt.
youre right, going from there
[tex]dP/dt=9P-(4+P/200)P[/tex]
[tex]5P-(P^2)/200[/tex]
[tex]P(5-P/200)[/tex]
[tex]dP/dt=P(1000-P/200)[/tex]
inversing i get
[tex]dt/dP=200/P(1000-P)=1/5P+1/5000-5P[/tex]
[tex]200/P(1000-P)=1/5P+1/5000-5P[/tex]
is from A=1/5, B=1/5 using partial fractions
[tex](1/5P+1/5000-5P)dP=200/dt[/tex]
im confused on what to do with [tex]200/dt[/tex]
how do you integrate that?
[tex]/int(1/5P+1/5000-5P)dP[/tex]
is [tex]1/5lnP+ 1/5 ln 5-5P[/tex] ?
You may want to use parenthesis to make it readable.
You have a differential equation of the form dt/dP=f(P) in equation line (6) therefore f(P)dP=dt and not 1/dt.
Integrate by using a substitution for the second fraction.
basically the equation becomes
[tex]\int (1/5) (1/P + 1/1000-P) = \int 200dt[/tex]
or you can't take the common factor of 1/5?
and how do you use parenthesis, still kind of new to these forums
Yes you can take the factor 1/5 out. Parenthesis are (). For example 1/1000-P as you've written it down is 0.001-P, but you mean [itex]1/(1000-P)=\frac{1}{1000-P}[/itex]. Where does the 200 come from? The rest looks good.
doesnt the 200 come from
[tex]dP/dt=P(1000-P)/200[/tex]
then i inversed
[tex]dt/dP = 200/(P(1000-P))[/tex]
and how do you make it so that it looks like a fraction? which tool was that
To create a fraction a/b you can write \frac{a}{b}.
You have the equation [itex]\frac{dt}{dP}=\frac{1}{5P}+\frac{1}{5000-5P}[/itex]. There is no 200 in there.
ohhhhhh right i forgot i turned [itex]\frac{200}{P(1000-P)}[/itex]
into [itex]\frac{1}{5P}+\frac{1}{5000-5P}[/itex]
so its possible to do
[itex]\frac{1}{5} \int \frac{1}{P} + \frac{1}{1000-P}[/itex] ?
Don't forget to put [tex]or [itex]brackets around your code. Yes you can now do the integral through a substitution.[/itex][/tex]
cant i just do
[itex]\frac{1}{5} \int \frac{1}{P} + \frac{1}{5} \int \frac{1}{1000-P}[/itex]
turning into:
[itex]\frac{1}{5} lnP + \frac{1}{5} ln(1000-P)[/itex]
forgetting my basics...
What you have written down now is no longer readable. Put \ in front of all your fractions. Anyhow you can check your answer by taking the derivative of your answer. Do it and you will see one term is correct and one is not.
ok it seems the term
[itex]\int \frac{1}{1000-P}[/itex]
is giving me trouble, what would be the substitution
Can you please fix your latex code before proceeding with making a new post. Post 9,11 and 13 need fixing. What kind of substitution do you think would help?
letting u = 1000-P
du = -1?
so confused
Looking good now. Don't forget the dP in your integration though. The substitution u=1000-P is the correct one. However what is du=-1... (something is missing here)?
i have totally forgot how to do integration using substitution,
you mean du=-1dP
will have to read up on it...
Yes that is correct. Now replace all Ps and dPs in your original integral with u and du.
does the equation become
just for the subtitution
[itex]\frac{-1}{ln(1000-P)}[/itex]
No. It appears that you do not know how to integrate by substitution. Looking at the problem you have presented you ought to have followed a course at some point that taught you how to do it. I suggest reviewing the basics of integration before continuing with this problem.
[itex]\frac{1}{5} lnP - \frac{1}{5} ln(1000-P)= t+C[/itex]
[itex]lnP - ln(1000-P) = 5t+5c[/itex]
using log rules
[itex]ln \frac{P}{1000-P} = 5t+5c[/itex]
multiplying by e
[itex]\frac{P}{1000-P}=Ae^{5t} , A=e^{5c}[/itex]
[itex]P = (1000-P)(Ae^{5t})[/itex]
multiplying it out
[itex]P=1000Ae^{5t} - PAe^{5t}[/itex]
[itex]P + PAe^{5t} = 1000Ae^{5t}[/itex]
[itex]Ae^{5t}= 1000Ae^{5t}/P[/itex]
[itex]P = 1000[/itex]
but how do i get P(t)
turns out i just had to use rearranging to find my P(t)
