What Is the Speed and Average Acceleration of the Minute Hand on a Clock?
The discussion revolves around calculating the speed and average acceleration of the minute hand on a clock, specifically with a radius of 25 cm. Participants are exploring the angular movement of the minute hand from the 12 o'clock position to the 2 o'clock position, questioning the angle covered and the implications for average acceleration.
  • Participants discuss the calculation of speed based on the circumference and time, and the angle covered by the minute hand. There are questions about the correctness of assuming the angle for the 2 o'clock position and which mathematical method to use for calculations. Some participants also explore the concept of average angular velocity and its implications for average acceleration.
There is an ongoing exploration of the calculations involved, with some participants providing calculations for average angular velocity and discussing the angle in both degrees and radians. However, there is no explicit consensus on the methods or assumptions being used, and some participants express uncertainty about the explanations provided.
Participants are working under the constraints of a homework assignment, which may limit the depth of exploration. There is mention of a lack of clarity regarding radians, indicating that this concept may not have been fully covered in prior discussions.
StupidGenius
Calculate the speed of the minute hand on the clock (I solved with the assumption of the minute hand being the radius) with the length of 25 cm.
How many degrees did the minute hand move through from 12" point to 2" point?
What is the average acceleration?
a=change in V/change in time
So i found the speed of the hand by finding circumference then divided over 3600 seconds.
Now I need to find the angle from 12" to 2". Is it right to assume that 2" is at 45 degrees, if 3" is 90 degrees?
Which method should I use the component or the trig method?
please help.
PS: is there a way to illustrate this and post it up?
I calculated the average angular velocity to be 1.745x10^-3 rad/s
Average acceleration will be 0, assuming that the average angular velocity is constant.
Is this what you are after?
there are 12 points on a clock face, so (2pi/12)*2 will give you the angle in radians between 12 and 2.
Its 60deg :P or pi/4
60 deg is right, but would you mind explaining it to me in a simpley way? or maybe introduce radians because we just skimmed over that section.
StupidGenius said:
thanks but still not quite sure how you arrived at the answer
What would happen if you cut a cake into 12 pieces and remove 2 pieces from the cake? How many degrees would the 2 pieces of cake be worth.
360/12 = 30, 30*2=60
Or in Radians, Pi = 180, so 2pi/12 *2 = pi/3
  • · Replies 16 ·
11K
  • · Replies 20 ·
