What is the speed of the water in the Bernoulli River?
  • Thread starter Thread starter Beastegargoyl
    Speed Water
The discussion revolves around calculating the speed of water in the Bernoulli River, formed by the confluence of River Pascal and River Archimedes. The combined volume flow rates are 4.7×10^5 L/s and 1.1×10^6 L/s, with the Bernoulli River having a width of 130 meters and a depth of 30 meters. Initial attempts at calculating the speed yielded incorrect results, with guesses of 0.120 m/s and 1.20 m/s. After clarifying the need to consider both rivers' flow rates, the correct speed was determined to be 0.40 m/s. The discussion emphasizes the importance of using the total flow rate for accurate calculations.
Beastegargoyl
River Pascal with a volume flow rate of 4.7×105 joins with River Archimedes, which carries 1.1×106 , to form the Bernoulli River. The Bernoulli River is 130 wide and 30 deep.
Express your answer using two significant figures.
I attempted to guesses so far.
0.120 m/s was wrong
1.20 m/s was wrong
Thanks for all the help.
Jared
Welcome to PF!
Hi Jared! Welcome to PF! :smile:
(try using the X2 tag just above the Reply box :wink:)
0.120 m/s was wrong
1.20 m/s was wrong
Show us your full calculations, and then we can see what went wrong, and we'll know to help! :smile:
For vfr=4.7*105L/s
I used the equation 4.7*105/3900 equals 1.2m/s
Thanks for the help.
Jared
Hi Jared! :smile:
(just got up :zzz: …)
Beastegargoyl said:
For vfr=4.7*105L/s
oh i see … you only used the volume flow rate of River Pascal.
The Bernoulli River contains the water of both River Pascal and River Archimedes. :wink:
@tiny-tim- Did you come up with an answer of .40m/s where that incportates both rivers?
Thanks for your help,
Jared
I go 4.0 times something
what are the units of the problem? :confused:
4.7*105L/s and 1.1*106L/s. 130m wide and 30m deep.
The answer needs to be expressed in m/s.
oh, litres! :rolleyes:
ok, then i make it .40m/s :smile:
