What is the Strategy for Evaluating Minimum and Maximum Values in Calculus?
15 replies · 2K views
a1234
The problem is in the attached file. The part I need a little help with is part b.
and attempt at a solution[/B]
For part a, I got h(8) = 2, h'(6) = -2, and h''(4) = -2.
For part c, I found that the integral from 0 to 5 is 7, so I multiplied 7 by 7 to get 49 (because 35 = 5*7). And f(5) = 0, so f(108) also equals 0. I got the tangent line y - 49 = 0(x - 35).
For part b, I think we're supposed to consider x = 0 and x = 3, since this is where the graph starts increasing from decreasing and vice versa. But I also think we have to evaluate the integral at these points. Can someone explain this?
If I consider
as an attempt, I agree with 0 and 3 but I don't see it decrease before 0... I also see another interval where f is not bigger than at 0 ...
If you want help for part (a) -- and I think you need it -- , please post your working in detail.
[edit] strike because the question is about ##h## and I mistakenly read ##f## --- bedtime :sleep:
haruspex said:
The period is not 5, so why is that interesting?
I thought the graph would keep repeating every 5 units, but that's not true.
It seems to repeat every 8 units, so could we do this?
integral from 0 to 8 = 1
8*4 = 32
1*4 = 4
integral from 0 to 3 = 3
4 + 3 = 7
y - 7 = 0(x - 35)?
You are told it does.
Didn"t you calculate it as 2 in part a?
a1234 said:
y - 7 = 0(x - 35)?
I do not understand that step. What is the gradient of h at x=35?
I didn't count the triangle from 0 to 1 when I first calculated the integral from 0 to 8. I think it should be 1 because the area of the trapezoid is -6, area of the large triangle is 8, and area of the small triangle is -1. So 8 + (-6) + (-1) = 1.
For the derivative at x = 35...
h(35) = integral from 0 to 35 = 7
h'(35) = f(35) = 4 because the graph repeats every 8 units...f(3) = 4 for the remaining 3 units after 8*4 = 32. So the derivative at x = 35 is 4.
If I put it into point-slope form, y - 7 = 4(x - 35) is the tangent line.
Ugh. I'm making a lot of mistakes here.
You're right, we only need the area of the trapezoid up to x = 8. So then the area of the trapezoid is 5, and h(8) = 2. The integral from 0 to 35 is 2*4 + 3 = 11.
y - 11 = 4(x - 35)
y - 11 = 4(x - 35)
Looks right.
The absolute maximum is the highest point over the entire graph. The absolute minimum is the lowest point over the graph. The relative max/min is the maximum or minimum over a certain interval.
I think the first step is to find do h'(x), which is just f(x) and find the critical points and endpoints of the graph. The critical points are 1 and 5, and the endpoints are 0 and 7. And then we need to evaluate g at those values. I came up with the following:
h(0) = 0
h(1) = -1
h(5) = 7
h(7) = 4
The absolute min is -1 and max is 7. The relative min is 0 and max is 4.
Okay. Thank you very much for the help!
