- 29,430
- 21,149
Okay, what about?jonjacson said:S=0=...+1-1+1-1...
T = -1 + 1 - 1 + 1 ...
The infinite series -1 + 1 - 1 + 1 - 1... does not converge in the traditional sense, as its partial sums oscillate between -1 and 0. However, it is Cesàro summable, yielding a sum of 1/2. This result is derived from the behavior of the series' partial sums, which approach 1/2 as the number of terms increases. The series exemplifies the complexities of infinite series and the importance of defining convergence accurately.
PREREQUISITESMathematicians, students of calculus, and anyone interested in the properties of infinite series and convergence criteria.
PeroK said:I've got to go, so let me make my point:
a) T = 0 by the same argument you used for S. Just group the terms.
But:
b) S = 1 + T. So, if T = 0, then S must be 1.
So, something must have gone wrong.
jonjacson said:We can continue talking another day, no problem.
a) T=1 because you forget that S contains a -1 for every +1, and that proportion holds no matter the size of the set. If you add +1 to create T there is no -1 as a counterparty, that is why T sums +1 and S sums 0, BECAUSE YOU ADDED AN EXTRA 1 that did not have his corresponding -1 in the series.
PeroK said:How do you know that S does not have an extra 1?
T = -1 + 1 -1 +1 ... = (-1 + 1) + (-1 + 1) ... = 0 + 0 + 0 ... = 0
So, T has just as much right to be 0 as S has. Why prefer S? Just because it starts with a positive number? I might prefer T = 0 and S = 1.
Also, why isn't T = -S?
Surely if you mutiply S by -1 you get T? So, how can S = 0 and T = -1?
Yes, they are equal.jonjacson said:Why? Why must I look one by one? Why can't I just put two terms together?
I mean, let's forget series, Isn't this +1-1 equal to (+1-1)?
FactChecker said:Yes, they are equal.
Suppose we allow -1+1-1+1... to be a valid infinite summation with a single answer.
On one hand, we have -1 +(+1-1) + (+1-1) +(+1-1) = -1 +0 +0+0...= -1
On the other hand we have (-1+1) + (-1+1) + (-1+1) + ... = 0+0+0... = 0
Which one is correct? This violates the associative property of addition, which is fundamental to all mathematics.
In math, a summation has a valid total only if changing the order or clustering of terms does not change the number that the partial sums eventually converge to. The associative and commutative properties of addition are not violated by the math definition of an infinite sum.
We either have to give up on -1+1-1+1... having a well-defined total, or we have to give up the associative and commutative properties of addition. The choice is clear. You will see eventually that "summations" like -1+1-1+1... are not very interesting and we haven't given up much.
No. They are the exact same numbers in the exact same order. The associative law has just been applied differently in the two cases. By the associative property, that is not allowed to give different answers.jonjacson said:Since in the first case you are telling us there are extra +1 that do not have their corresponding -1.
jonjacson said:Every time you represent T you forget to show you added an extra +1 to S, let me show that extra +1 and all your confusions will dissapear:
T= ...-1+1-1+1+1-1+1-1+1
S=...-1+1-1+1-1+1-1+1-1
FactChecker said:In math, a summation has a valid total only if changing the order or clustering of terms does not change the number that the partial sums eventually converge to. The associative and commutative properties of addition are not violated by the math definition of an infinite sum.
But you are grouping the terms in a certain way. In an absolutely convergent series, reordering or grouping don't change the sum. The series in question here is not absolutely convergent, so reordering and grouping aren't valid.jonjacson said:What I think is accepting the sum is = 0 does not generate any inconsistency nor absurd result and I would like you to demonstrate where I am wrong since I am not even rearranging terms.
You can't just assume that the series in question is convergent.jonjacson said:I have a question for you, assuming the reesult is 0, Does it violate any mathematical rule like associative?
