What is the tension in the rope?
The problem involves a mass being raised by a man climbing a rope over a frictionless pulley. The mass of the man is given as half that of the mass being lifted, and the man climbs with a specified acceleration relative to the rope. The goal is to determine the tension in the rope based on these conditions.
  • Mixed
  • Participants discuss drawing free body diagrams for both the mass and the man, exploring the forces acting on each. There are attempts to relate the accelerations of the man and the mass, as well as the tension in the rope.
Some participants have provided guidance on considering the kinematics involved and the relationships between the forces acting on the man and the mass. There is ongoing exploration of how to relate the frictional force to the tension in the rope, with various equations being proposed and questioned.
Participants note confusion regarding the forces involved, particularly the role of friction and how it relates to tension. There is also mention of discrepancies in the equations being used, indicating a need for clarification on the setup and assumptions made in the problem.
ItsAnshumaan
In order to raise a mass 'm' a man ties it to a rope and passes the rope over a friction less pulley. He climbs the rope with an acceleration 3g/2 relative to the rope. If the mass of the man is m/2 and the mass of the rope is negligible, the tension in the rope is
a) 3mg/2
b) 5mg/2
c)7mg/6
d) 9mg/7
F=ma
So basically we have a friction less pulley, and over which passes a rope. One end has been connected to the mass 'm' which, on drawing the free body diagram will show two forces, mg and the tension. While the other end, where the man is climbing the rope is getting very messy to approach with :/
Welcome to PF!
In terms of dealing with the forces applied to the man, it is really not different than dealing with the forces on the mass m. Can you describe your attempt to draw a free body diagram for the man?
Most pulley problems must start out with a consideration of the kinematics. If the mass is downward with an acceleration a (relative to the ground), what is the upward acceleration of the portion of the rope on the man's side of the pulley (relative to the ground)? If the man is moving upward relative to the rope on his side of the pulley with an acceleration 3g/2, in terms of g and a, what is the man's acceleration relative to the ground?
TSny said:
Welcome to PF!
OK here is what I tried to do
So I am not able to figure out what to do with the force which is helping the man to climb up.
The mass is actually moving up, I can figure out that the only equation we can get out of that mass is: T - mg = m a1 (Here I am considering a1 as acceleration of the rope and a2 as the acceleration of the man relative to the rope).
So the man's acceleration with respect to ground must be; a2 = 3g/2 + a1
What equation do you get from setting up Newton's second law for the man?
For the relation between a1 and a2, you will need to be careful with the signs. For instance, if the rope were accelerating downward on the right side of the pulley at 2 m/s2 and the man were accelerating upward at 3 m/s2 with respect to the ground, then what would be the value of the acceleration of the man with respect to the rope?
Yes, the value of the acceleration of the man with respect to the rope would be basically 1 m/s2 upwards.
Okay so with that knowledge, I can say that the man is moving up with an acceleration (3g/2 + a1) m/s2, and the overall sum of all the forces acting on the man would be equal to (m/2)(3g/2 + a1).
Now regarding the free body diagram of the man, I get 2 forces: 1) Weight(vertically downwards = mg/2) 2) And the other force I think must be the frictional force helping the man to move up.
I am not sure regarding the 2nd force, I am getting confused at that point. I don't exactly understand which force is responsible for the man to help climb the rope.
Actually, it would not be 1 m/s2. If the rope on the right side were accelerating upward at 2 m/s2 with respect to the ground while the man accelerated upward at 3 m/s2 with respect to the ground, then the acceleration of the man with respect to rope would be 1 m/s2. But what if the rope on the right side accelerates downward at 2 m/s2 with respect to the ground while the man accelerates upward at 3 m/s2 with respect to the ground?
This is not correct if a1 represents the downward acceleration of the rope on the right side.
Yes, the upward force on the man is the friction force from the rope and the downward force on the man is the weight of the man. Can you see a relation between the friction force and the tension in the rope?
TSny said:
Actually, it would not be 1 m/s2. If the rope on the right side were accelerating upward at 2 m/s2 with respect to the ground while the man accelerated upward at 3 m/s2 with respect to the ground, then the acceleration of the man with respect to rope would be 1 m/s2. But what if the rope on the right side is accelerating downward at 2 m/s2 with respect to the ground while the man accelerated upward at 3 m/s2 with respect to the ground?
Oh right finally understood, 5m/s2 upwards.
So then, 3g/2 = a1 + a2, that means acceleration of the man is; a2 = (3g/2 - a1).
Then for the man, the relation would be: f - mg = (m/2)(3g/2 - a1). Is this correct now? (f is the frictional force)
Yes. That all looks good. Just need to figure out how f is related to T.
Edit: I just noticed that you don't have the correct mass on the left side of your last equation above.
Sorry that would be f - mg/2 = (m/2)(3g/2 - a1).
But I am unable to draw the relation between f and T..
If the rope pulls upward on the man with the force f, then the man pulls down on the rope with the force f. Consider the section of rope that experiences the downward force f from the man. The net force on this section must be zero (since the rope is massless and a nonzero net force would cause the section to have infinite acceleration). So, some other force must act on this section of rope.
Oh yes, so that force must be the tension. In that case T = f, or T = mg/2 + m/2(3g/2 + m a1)
So the earlier equation i had for the block was, T - mg = m a1.. So a1 = (T - mg)/m
Putting the value of a1 in T = mg/2 + m/2(3g/2 + m a1), I am very unfortunate to get the value T = {mg(4-m) / (2-m)}, as there is no such option from the multiple given answers.. Any idea where I went wrong?
## T = \frac{mg}{2} + \frac{m}{2} ( \frac{3g}{2} + m a_1) ##
First, Why is there ## m a_1 ## ? Why do you have the mass of the object in there?
Second thing is, You already have an equation for the acceleration of the man to something stationary (Ground) and it is ## a_2 = \frac{3g}{2} - a_1 ##
Why is there a plus sign in your equation?
Try now and see if it gives you the correct answer
Thanks a lot! Turns out that I had copied the equation wrong. Yes it worked, and the answer I got is 7mg/6, perfectly the 3rd option! :)
Thanks Chestermiller, TSny and Biker for your help, now I am able understand the pulley problems to the core!
No problem at all, Welcome to Physics forums
Glad to hear that :D
  • · Replies 38 ·
  • · Replies 22 ·
  • · Replies 25 ·
