Tension in string between blocks with applied forces
  • Thread starter Thread starter A_lilah
    String Tension
1 reply · 3K views
A_lilah
3.7 kg block A and 6.0 kg block are connected by a string of negligable mass. Force FA = (13 N) acts on block A; force FB = (24 N) acts on block B. What is the tension in the string? (both force FA and FB are to the right)
fnet = ma
Block A FBD:
Weight force down of m*g = 36.297N
Normal force up (opposite of weight)
frictional force to the left = f1
FA to the right = 13N
Tension, T, to the right
Block B FBD:
Weight force down = 58.8N
frictional force to the right = f2
FB to the right = 24 N
Tension force, T, to the left
equations:
Fnet Ax = 3.7kg * a = 13N + T - f1
Fnet Bx = 6kg * a = 24N -T + f2
Fnet of A and B together = 9.7 kg * a = 37N + f2 -f1
Problem: four unknowns and only three equations...
One of those equations is extraneous, so you really just have 2 equations with 4 unknowns. If the surface is frictionless, f1 and f2 are 0; if friction is involved, the problem needs to state the friction coefficients, otherwise, you can't get a numeric answer. IF friction is involved, you made an error on the sign of f2..why did you have it as plus? (I'm guessing that the floor is horizontal and frictionless? If friction were presnt, the system might not move).
