What is the value of ω for a RLC AC circuit with given parameters?
The discussion revolves around determining the correct value of angular frequency (ω) for a given RLC circuit with an AC power source. The original poster is trying to find the reactance of a capacitor using provided circuit parameters.
  • The original poster questions whether to use the frequency (3000 Hz) directly as ω or to calculate it using the formula ω = 2 π f. Some participants clarify that ω should be calculated as angular frequency, leading to further confusion regarding terminology used by the teacher.
Participants are exploring the distinction between frequency and angular frequency, with some providing guidance on the correct formula to use. There is an ongoing clarification of terms, but no consensus has been reached regarding the teacher's terminology.
There is a noted confusion stemming from the teacher's use of the term "frequency" when referring to ω, which is typically understood as angular frequency. This may affect the understanding of the problem setup.
musiliu
I am given a RLC circuit with a AC power source (e.g. signal generator), and i want to find the reactance of the capacitor.
Given: R = 2200 Ohms, L = .025 H, C = (1 x 10-9) F, V0 = 5 V
f = 3000 Hz
edit: Sorry i wrote wrong formula.. here is the correct one:
Reactance of Capacitor = 1 / ω C
I know how to solve this problem, but i am not sure what value to use for ω.
My teacher refers to ω as the "frequency", but isn't it supposed to be ω = 2 pi f ?
So, simply put, am i supposed to use the 3000 Hz as my ω, or do i use 2 pi f as my ω?
Use ω = 2 π f. Also there is no V0 in the reactance.
i learned that ω is the angular frequency.. so am i supposed to use ω = 2 pi f for this problem? i am confused since my teacher keeps calling ω the frequency and not the angular frequency...
It is a bit confusing at first because your teacher is cutting corners. You can tell whether one is talking about ω or about f by looking at the units. When you see rad/s (or s-1), it is ω. When you see Hz (or cycles per second), it is f.
