What is the volume of a tank that is 8 ft in diameter and 15 ft high?
The volume of a cylindrical tank with an 8 ft diameter and a height of 15 ft is calculated using the formula V = Ah, where A is the cross-sectional area. The correct area A is determined using A = πD²/4, resulting in A = 50.24 ft². Therefore, the volume V is calculated as V = (50.24 ft²)(15 ft), yielding a final volume of V = 753.6 ft³. It is important to use a precise value for π, as 3.14 is merely an approximation.
  • Understanding of cylindrical geometry
  • Knowledge of the mathematical constant π
  • Ability to perform basic arithmetic operations
  • Familiarity with volume calculation formulas
  • Study the properties of cylinders in geometry
  • Learn about the significance of π in various mathematical contexts
  • Explore advanced volume calculation techniques for irregular shapes
  • Practice solving volume problems involving different geometric figures
Students, educators, and professionals in fields requiring knowledge of geometry and volume calculations, particularly in engineering and architecture.
jim1174
What is the volume of a tank that is 8 ft in diameter and 15 feet high
Π x (4ft) 2 x 20ft
3.14 X 24ft x 15ft = 1130.4
13.4 X 24ft X 15ft= 1130.4
It's not clear where the figures 13.4 and 24 come from. Also, the word 'diameter' implies that the tank is a cylinder.
D = diameter = 8 ft
h = height = 15 ft
A = cross-sectional area = to be determined
V = volume = to be determined
A = πD²/4
A = (3.14)(8 ft)²/4
A = 50.3 ft²
V = Ah
V = (50.3 ft²)(15 ft)
V = 754 ft³
jim1174 said:
D = diameter = 8 ft
h = height = 15 ft
A = πD²/4
A = (3.14)(8 ft)²/4
A = 50.3 ft²
V = Ah
V = 754 ft³
This looks good.
jim1174 said:
D = diameter = 8 ft
h = height = 15 ft
A = πD²/4
A = (3.14)(8 ft)²/4
A = 50.3 ft²
V = Ah
V = 754 ft³
I hope you realize that 3.14 is not the value of ##\pi##, but is just a 3-digit approximation to the true value (and which is sometimes close enough in some problems, but not nearly accurate enough in some other cases).
jim1174 said:
. The attempt at a solution
Π x (4ft) 2 x 20ft
Just to clarify your initial work, in your first expression above, you have 20 ft where it should have been 15 ft. I understand that "(4ft) 2" is supposed to be 42, which can also be written as 4^2.
In your second expression you corrected the 20ft dimension, but 4 X 4 ##\neq## 24.
ok i think i got it
D = diameter = 8 ft
h = height = 15 ft
A = πD²/4
A = (3.14) (8 ft) ²/4
A = 50.24 ft²
V = Ah
V = (50.24 ft²) (15 ft)
Volume V = 753.6 ft³
Final Answer is = V = 753.6 ft³
12K
  • · Replies 17 ·
