What is the wavelength of a pulse on a hanging rope with changing tension?
The problem involves a uniform rope hanging vertically with a block attached, where a transverse pulse is produced at the lower end. The discussion centers on how the wavelength of the pulse changes as it travels up the rope, considering the varying tension along its length.
  • Participants explore the relationship between tension and wavelength, questioning how the frequency remains constant despite changes in tension. Some express uncertainty about the implications of sending multiple waves and their timing.
The discussion is active, with participants engaging in clarifying the relationship between frequency and wavelength. Some guidance has been offered regarding the constancy of frequency, but there remains some confusion about the implications of amplitude and vibration direction.
Participants are navigating assumptions about wave behavior in a medium with changing tension, and there is an ongoing exploration of how these factors influence the characteristics of the waves produced.
harambe
A uniform rope of length 12cm and mass 6kg hangs vertically from a rigid support.A block of mass 2kg is attached to the free end of the rope.A transverse pulse of wavelength 0.06m is produced at the lower end of the rope.What is the wavelength of the rope ,when it reaches the top of the rope
So It is given that the wavelength changes and the tension also changes through out the rope
T(upper segment)= 8g,T(Lower segment)-=2g
The wave equation
v1/v2=(T1/T2)^1/2 {the mass perunit length cancels for this case}
Now velocity of a wave= wavelength X frequency
The wavelength is changing through out the rope and I don't know about frequency so How should I proceed after this...Does the derivation consider the fact that the wave changes velocity at every point on the rope
If 100 complete waves are sent up will they all take the same time to reach the top? What does that tell you about how the frequency at the bottom compares to the frequency at the top?
They will take same time so frequency should remain constant
Right, so can you now determine the wavelength change?
The frequency remains same so use the relationship between wavelength and velocity to solve this
yeah and I got my answer now
The elements in the upper part might vibrate less that the elements at the lower part leading to decrease in the frequency.
I still can't understand how your example leads to the explanation that frequency is constant all over the rope.
The waves might change amplitude, but they will not disappear completely, nor will extra waves appear out of nowhere. If the frequency at the bottom is persistently greater, say, than the frequency at the top then then the number of waves in between must be increasing, without limit.
Thank you very much sir.
That is quite vague, so I am not sure what your reasoning is.
What do you mean by vibrating less? Less amplitude, yes, but less often, no.
Start with one pulse sent from the bottom. It takes some time t to reach the top.
Now send the next pulse. Doesn't that also take time t to reach the top?
I agree that all the pulses will take same time to reach the top but how it relates to constant frequency?
Now consider pulses emitted at times ##t_0, t_0+T, t_0+2T, ...##. They arrive at the top at times ##t_0+t, t_0+t+T, t_0+t+2T, ...##.
So vibration is in vertical direction (up-down) , I thought it was in horizontal axis (left-right).
Makes no difference to the argument.
I see that time period of all the pulses will be same so all the pulses will have same frequency(up-down vibrations) so it is about vertical vibrations and not horizontal with which I confused .
It does not matter whether they are vertical or horizontal. The pulses must arrive at the same rate at which they start, so the frequency is the same.
  • · Replies 39 ·
10K
