What is the work done by braking force on a decelerating car?
  • Thread starter Thread starter Lauren0619
    Car Work
The discussion revolves around calculating the work done by the braking force on a decelerating car, specifically focusing on a car with a mass of 1480 kg that decelerates from a speed of 91.0 km/hr to a stop. Participants are exploring the implications of significant figures in their calculations and the correct conversion of speed from km/hr to m/s.
  • Mathematical reasoning, Assumption checking
  • Participants discuss the conversion of speed from km/hr to m/s and its impact on the calculation of work done. There are questions about how to handle significant figures in the calculations, particularly regarding the initial speed and the resulting values.
There is an ongoing examination of the conversion process and the significance of figures in the calculations. Some participants have provided guidance on maintaining significant figures, while others are verifying their calculations and discussing potential discrepancies in their results.
Participants are considering the implications of significant figures based on the precision of the initial data provided. There is also a focus on ensuring that the negative sign is appropriately included due to the nature of deceleration.
Lauren0619
With brakes fully applied, a 1480 kg car deccelerates from a speed of 91.0 km/hr. What is the work done by the braking force in bringing the car to a stop?[/B]
1/2(mass)(v^2)
1/2(1480)(25^2) = 462500
I converted km/hr to m/sec to get 25 for the v value. They want us to include the sign of the acceleration so i added a negative sign to make the answer -462500 but it was wrong (I also tried it without the negative sign). What am I missing? Thank you so much![/B]
Consider the number of significant figures given in the numerical data. When you calculate v in m/s, you should keep at least that same number of significant figures. (I like to keep an extra significant figure during the intermediate calculations and then round off to the appropriate number of significant figures at the end of the calculation.)
Thanks for your quick reply, TSny, For the significant figures and multiplication I know that you use the value with the least amount of numbers (precision). So for this one would I be basing it off of .5? or 25? If it was .5 I would write it as 4x10^5. If it was 25, I would write it as 4.6 x 10^5. I'm just not sure which one to use? And I would still include the negative sign for the acceleration, do you agree?
How many significant figures are in the quantity 91.0 km/hr?
When you convert this to m/s, how many significant figures should you retain?
Trailing zeros are significant, so 3 sig figs are in 91.0. So converting to m/s it would be 25.0 m/s? So then my answer should be -4.62 x 10^4 retaining the 3 significant figures? Thanks again for being helpful and patient.
Yes.
You have the correct number of significant figures, but the last digit is not 0. Check your conversion of km/hr to m/s.
It looks like you already got your answer. To be explicit, the .5 is a scalar therefore its significance is neglected (see https://en.wikipedia.org/wiki/Significance_arithmetic). I agree with your negative notation since you're going from a higher speed to rest, hence decelerating. (For further clarification, see https://www.av8n.com/physics/acceleration.htm).
Cheers
Check your conversion to m/s -- see this for a step-by-step guide.
Using 25 m/s vs 25.3 m/s makes a huge difference in the answer
Thanks everyone! I redid my conversion and got 25.3 (rounding up) for my meters per second. Recalculating I got 4.73 x 10^4. Keeping 4.73 consistent with 3 significant figures. And I will mark it as negative since it is decelerating. Did I finally get it?
The 4.73 looks good, but I think you should check the 104 part.
That was a silly mistake on my part. Thanks for catching that. My answer in full is 473666.6 which converted into scientific notation will result in a complete answer of -4.73x10^5 or should I round it up to -4.74x10^5? Again, thanks all for the patience.
If you round 473666.6 to three significant figures, you would "round up" to obtain 474000.
As I mentioned in an earlier post, I prefer to keep an extra significant figure in intermediate calculations.
So, I would have obtained v = 25.28 m/s. This would give -472918 for the work, which rounds to -473000 to three significant figures. You can see how you might obtain either -4.73 x 105 or -4.74 x 105. So, in my opinion, either answer should be acceptable. I leave it to you to include the correct units.
  • · Replies 19 ·
  • · Replies 29 ·
  • · Replies 33 ·
