What is Torque and what is correct formula?
  • Context: Undergrad
  • Thread starter Thread starter urbano
    Formula Torque
This discussion clarifies the concept of torque, defined by the formula τ = r × F, which represents the rotational effect of a force applied at a distance from a pivot point. It distinguishes between torque and moment, noting that while some sources use the terms interchangeably, others emphasize their differences, particularly in physics contexts. The second formula τ = I × angular acceleration is derived from Newton's second law and describes the relationship between torque and angular momentum. Understanding these formulas is essential for grasping the dynamics of rotational motion.
  • Basic understanding of Newton's laws of motion
  • Familiarity with concepts of force and linear momentum
  • Knowledge of angular momentum and moment of inertia
  • Understanding of vector operations, specifically cross products
  • Study the relationship between torque and angular momentum in detail
  • Learn about moment of inertia and its calculation for various shapes
  • Explore the applications of torque in real-world mechanical systems
  • Review introductory physics textbooks like Halliday and Resnick for foundational concepts
Students in introductory physics courses, educators teaching mechanics, and anyone interested in understanding the principles of rotational dynamics and torque applications.
urbano
I'm struggling with the concept of torque as I read more I get further confused.
I read some sources and they say torque and moments are interchangeable, yet other sources make a specific effort to keep the two separate. So question one is , what is the difference between torque and a moment ?
The formula for torque...so far I have come across τ= r ×F, but also τ = I ×angular acceleration. I'm unsure which I should be using, and if both, which circumstances determine you to use which.
My overall confusion though is what is torque?
So moment of inertia is the resistance to the force being applied. So is torque the amount of force I need to apply to rotate an object ? or is it the amount of rotational force a force can put on a body ? what is a Nm (Newton meter) how would one see a Newton meter, I presume its not a rate or ratio.
thanks for any help.
"τ= r ×F"
This is, correctly applied, the DEFINITION of torque.
By correctly applying the definition of torque on Newton's second law of motion, F=ma, we gain the RESULT
"τ=I ×angular acceleration" for the rigid body.
"ma" in F=ma is often called "the rate of change of (linear) momentum", whereas "I ×angular acceleration" is often called "the rate of change of angular momentum".
To some, torque and moment (of force) are synonyms. To some engineers, they're not. They distinguish between moment of force and torque. So, yes, there is a potential for confusion. This is physicsforums.com, not engineeringforums.com, so at this site it's best to stick with the nomenclature used in physics.
By way of analogy, consider a mass attached to a spring. On one hand, Hooke's law describes the force exerted by the spring on the mass is F=-kx, where x is the displacement from the spring's relaxed position. On the other hand, we have F=ma from Newton's laws of motion. Presumably you aren't confused by F=-kx versus F=ma, so why should you be confused by τ=r×F versus τ=Iα?
In the spring mass system, F=ma is a kinematic description of what transpires. F=-kx is a dynamic description of what's happening. Put the two together and you get a second order differential equation, ##m\frac{d^2x(t)}{dt^2} = -k x(t)##. The same happens with rotational motion. τ=r×F is a dynamic description of torque. τ=Iα is a kinematic description. Put the two together and you get a second order differential equation that describes what's happening rotationally.
I view the two formulas as cause and effect: If you apply a force \vec{F} at position \vec{r} on a rigid object, it will cause the object to increase its rate of angular velocity \omega according to the formula:
\vec{r} \times \vec{F} = I \cdot \dot{\vec{\omega}}
(In general, I is a tensor, so the operator \cdot is a tensor operation.)
The first two posts are excellent but may be a bit advanced if your are just starting this
subject. So study them carefully.
[Third post made while I was typing this...] Some reasonable explanation and details are here:
http://en.wikipedia.org/wiki/Torque
By definition, torque τ = r × F. Therefore torque on a particle is equal to the first derivative of its angular momentum with respect to time.
You can also check any good introductory physics textbook like Halliday and Resnick.
that's the idea, but I'd say ...is the ROTATIONAL resistance to the force...Trying to rotate a body usually takes a different force than trying to move the body linearly.
The resistance to a linear force is referred to as 'inertia'.
yes, but at some specified distance 'r' as described in the Wikipedia link...
Via Tau [torque] = r x F torque varies both from the force F and the distance of the applied force from the point/axis of rotation.
refer to the prior equation.
I assume you know a 'Newton' is a unit of force in the MKS system. A Newton meter is such a force applied at a specified distance from the axis of rotation. You can't 'see' such but you may be able to observe the result...rotational motion. Analogously, a Newton [meaning applied linearly] might move an object, say against friction or gravity.
Even more generally, the left hand side should be a sum over all external forces, and the right hand side should be the derivative of angular momentum:
\sum \vec r \times \vec F = \frac d{dt} (I\cdot \vec \omega)
In the special case that the moment of inertia can be treated as a constant scalar, this becomes
\sum \vec r \times \vec F = I\dot{\vec{\omega}}
This is the appropriate equation for introductory level physics.
The original poster is asking some very introductory level questions, so it's best to ignore the tensorial nature of the moment of inertia. Besides, your equation is not correct if you do look at moment of inertia as a tensor.
Thread temporarily locked for cleanup.
Posts which are a bit above the level of a high school / freshman level understanding have been split to a different thread, [thread]711348[/thread].
Please keep remaining posts on topic and in line with what a young person taking a first year class in physics would understand.
Thread re-opened.
  • · Replies 49 ·
  • · Replies 69 ·
  • · Replies 138 ·
