What is the best laser for replicating this experiment?
The discussion centers on selecting an appropriate laser for replicating the experiment detailed in the paper "http://arxiv.org/pdf/1505.04254v1.pdf". The user is considering a 1.5W 450 nm laser from jetlasers.org, the same supplier as the original research team, despite the specific model being unavailable. The experiment will be conducted in a vacuum environment at a high school, with safety precautions in place. The user seeks confirmation that the chosen laser specifications are optimal for the experiment.
  • Understanding of laser specifications, particularly wavelength and power
  • Knowledge of vacuum apparatus and its application in experiments
  • Familiarity with laser safety protocols
  • Basic comprehension of the experimental methodology outlined in the referenced paper
  • Research the characteristics and applications of 450 nm lasers
  • Explore laser safety guidelines specific to educational settings
  • Investigate alternative suppliers for high-power lasers suitable for similar experiments
  • Review vacuum system setup and maintenance for experimental use
High school students, educators, and researchers interested in replicating laser-based experiments, particularly those involving vacuum environments and laser safety considerations.
J. Cole Kaplan
If I were to replicate this experiment http://arxiv.org/pdf/1505.04254v1.pdf but was limited to the purchase of only one laser which frequency and what power should I choose? I know the research team that conducted this experiment purchased their lasers from jetlasers.org but they unfortunately no longer sell the exact model of laser the team used. Any input would be very much appreciated. Thank you.
Science news on Phys.org
Most of the experiments in that paper are done under vacuum. Do you have any vacuum apparatus at your high school where you are a senior? Also, have you read a bit on laser safety? Will you be doing these experiments at school, or on your own?
Yes. We have the equipment necessary to create the vacuum and are aware of and will take all required precautions in order to perform the experiment carefully and safely. The experiment will be performed at the school. We are in the process of putting in purchase orders for the rest of the materials we need. We are considering purchasing a 1.5W 450 nm laser from the same company the research team purchased from but I wanted to be certain this is the best one we could choose. Thank you for your concern.
  • · Replies 17 ·
  • · Replies 16 ·
