What Motor Power is Needed for a 2-3kg Helicopter?
  • Thread starter Thread starter goral09
    Power
To successfully lift a 2-3 kg helicopter, a minimum thrust of 20-30 N is required. The lift must equal the weight of the helicopter to achieve hover, negating the need for acceleration greater than 9.8 m/s². Testing various motors with a propeller and measuring thrust using a spring scale is an effective method to determine the necessary motor power. This approach allows for practical experimentation to identify suitable motors for the desired lift capacity.
  • Understanding of basic physics principles, specifically Newton's laws of motion.
  • Familiarity with helicopter design and aerodynamics.
  • Knowledge of thrust measurement techniques, such as using a spring scale.
  • Experience with electric motors and propeller dynamics.
  • Research electric motor specifications for RC helicopters, focusing on thrust-to-weight ratios.
  • Learn about propeller selection and its impact on lift and efficiency.
  • Explore thrust measurement techniques, including the use of spring scales and digital thrust meters.
  • Investigate helicopter flight dynamics to understand hover and stability requirements.
Aerospace hobbyists, RC helicopter builders, and engineers interested in understanding motor power requirements for small-scale aerial vehicles.
goral09
Hi everyone,
I'm thinking about building x-ufo helicopter, and I'd like to know how strong motors I need. I've been looking for some info in the internet but didn't came across anything interesting. Can you help me and show me a book or a site where i can find some tips and infos
I want to lift 2-3kg helicopter.
I know that if I want my helicopter to lift it has to have greater acceleration than g = 9.8 m/s^2, if I want it to stand still motors have to produce enough power to balance the gravity. But these are the most basic laws, what next?
Hi there goral09, if you want to lift a 2-3 kg helicopter you need a minimum of 20 - 30 N of lift. Your helicopter doesn't need an acceleration capability of 9.8 m/s^2 technically as that's factored into the Weight, which is W = mg. So in order to hover your Lift needs to equal Weight (W). I can't really help you out on the motors though. You could maybe test a few motors with a prop, and have it pull on a spring scale to see how much thrust is produced, and then deduce how many you would need.
20K
  • · Replies 36 ·
  • · Replies 31 ·
19K
17K
  • · Replies 23 ·
9K
