What physics will you use to find the speed?
5 replies · 3K views · last reply
deanine3
Suppose a car starts from rest and rolls down a hill that is 50 m high. You are going to find the speed of the car at the bottom of the hill. What physics will you use to find the speed? Now find the speed.
KE= 1/2mv^2
PE= mgh
Speed= distance x time
I am not sure where to start since there is so little information. 50m (height) x 9.8 m/s^2 (gravity)= 500 m^2/s^ but is this PE? KE? I don't have mass so I don't think its PE, and I'm sure it's not KE.
What I know: its initial velocity is 0, height is 50m, since it is "falling" it is under the influence of gravity 9.8 m/s^2.
If it is falling 50 m at 9.8 m/s that's 5.102 seconds "falling"? So the speed is 5.102s x 50m = 255.01 m/s? Is this correct? Am I along the right lines?
This is a conservation problem. Choose the bottom of the hill as h=0. This will make solving for the unknown easy, even though you can choose h=0 at the top if you wish.
So, initially the car is at rest, so it has zero kinetic energy. Since I took h=0 at the bottom, the car has gravitational potential energy at the top. At the bottom, the car will have some final kinetic energy and zero gravitational potential energy since h=0 there.
So simply set up your equations and solve for v:
[tex] \begin{gathered}<br /> K_o + U_o = K_f + U_f \hfill \\<br /> U_g = K_f \hfill \\<br /> mgh = \tfrac{1}<br /> {2}mv^2 \hfill \\<br /> gh = \tfrac{1}<br /> {2}v^2 \hfill \\<br /> v = \sqrt {2(9.8\tfrac{m}<br /> {{s^2 }})(50m)} \hfill \\<br /> v \approx 31.3\tfrac{m}<br /> {s} \hfill \\ <br /> \end{gathered} [/tex]
I think I am getting however, how do you take out the 1/2 from the v^2 side of the equation? I don't see where it went.
deanine3 said:
or are both sides multiplied by 2?
Yes. Then you are taking the square root of 2gh to get v. :smile:
Ok, I really think I have it! When you divide by 2, it becomes 2gh=v^2. The v^2 becomes v=square root sign. Then, under the square root sign you plug in the 2 (from the previous division), gravity, and the height! This is slowly making sense.
