What Sets a Current Pulse Apart from a DC Circuit?
2 replies · 17K views · last reply
Gear300
A current pulse exists, in which the current jumps from 0A to 10A, stays at 10A for 200 microseconds, then drops from 10A to 0A. What makes a current pulse different from the current that runs when a switch in a DC circuit is left closed for 200 microseconds...is it the same concept?
A current pulse is a current that runs for a short time. Closing a switch in a DC network for a short time will likely produce a current pulse. Getting a clean pulse with length 200 microseconds with an analog switch is rather hard, and a current pulse of this length is better generated with a digital switches.
Oh...so let's say that a current pulse for 200 microseconds existed...could we take it that inductance is negligible? The problem I was doing involved a partial branch of a circuit with a .01H inductor parallel to a 100 Ohm resistor. It stated that a current pulse existed, in which it jumped from 0 to 10 Amps, stays for 200 microseconds, then drops to 0A (these values are for the current before the junction). The problem asked me to come up with a function of time for the current through the inductor for that period of 200 microseconds, but to come up with the answer they gave, we have to assume that the current before the junction is unaffected by the inductor (remains 10A for that period)...also, the rate at which the current jumps and drops is almost a straight vertical line...it was as if the phenomenon of inductance was completely neglected; so I was assuming this might be a little different from simply closing a DC circuit for 200 microseconds.
