What shape would produce the greatest electric field?
The discussion centers on determining the optimal shape for maximizing the electric field produced by an incompressible material with a constant charge density. It is established that the largest electric field concentration occurs at pointed ends, while flat or spherical surfaces minimize the field. This principle is applied in high voltage devices, where sharp tips are utilized for emission, and smooth surfaces are preferred to prevent unwanted discharge. The conversation also touches on the relationship between charge movement and constant charge density, referencing a related problem in gravitational fields.
  • Understanding of electric fields and charge density
  • Familiarity with calculus of variations
  • Knowledge of electrostatics principles
  • Experience with high voltage device design
  • Research the mathematical derivation of electric fields from charge distributions
  • Explore the effects of shape on electric field strength in electrostatics
  • Study the principles of brush discharge and its implications in insulators
  • Investigate the design and operation of Van de Graaff generators
Physicists, electrical engineers, and anyone involved in the design of high voltage systems or studying electrostatics will benefit from this discussion.
Helmholtz
Suppose you are given an incompressible material with a constant charge density. What shape would create the largest electric field at a given point in space? These seems like a calculus of variation problem, but I am wondering if there might be any clever trick.
$$\vec E = \frac{\rho}{4 \pi \epsilon_0} \iiint \frac{\hat r}{r^2}dx' dy' dz'$$
The largest field concentration occurs at the pointy end ... and is minimized by flat or spherical surfaces.
Thus inside any high voltage device a very sharp tip is used for emission, and mirror polished smooth surfaces are used wherever emission is not desired. Knowing the answer, you can now look for clever tricks.
Isn't this for conducting materials, where the charges can move? For "constant charge density" the problem seems similar to this problem about maximizing the gravitational field with a constant mass density object:
http://pages.physics.cornell.edu/~aalemi/random/planet.pdf
Brush discharge from an insulator increases with angularity ... a sharp tip (eg, a crack or edge) will generate a discharge long before a nice smooth surface. You can see this in action if you have a Van de Graaff generator handy.
UltrafastPED said:
Brush discharge from an insulator...
If there can be a discharge, it means that charges can move. So how can you be sure there is constant charge density, as the OP states?
Thank you for the reference paper, I found that to be a great help. I believe I now understand what the answer is, as derived in the paper.
  • · Replies 29 ·
