What space contracts in Special Relativity?
62 replies · 9K views · last reply
dubiousraves
Hi. I know that space for an object in motion will contract, relative to an observer. We generally read that space contracts for the object in the direction of motion. But doesn't space around the object also contract? Can someone clarify this? Thanks.
I don't think this is a good way of thinking about length contraction.
According to the theory of relativity, the length of an object in motion (along the direction of motion) is shorter than if the object was at rest. This is least ambiguous way of describing length contraction.
The problem with characterizing length contraction as a contraction of space itself is that space doesn't contract. Space is always defined relative to an observer. Suppose someone named Alice is observing an object. If that object starts moving, Alice's description of space doesn't change at all. Rather, the object just shrinks.
Hendrik Lorentz, for whom the Lorentz transforms are named, had a theory that would explain the contraction of a moving object- since the magnetic field of a charged object was NOT invariant under motion, he suggested that in some, as yet unknown, way, the magnetic field in a moving object was stronger in the direction of motion and so caused it to contract. That would cause a material object to contract, not the space around it. But later experiment (in particular the "Kennedy experiment" which was like the Michaelson-Morley experiment but with arms of differing length, showed that this is not true. Contrary to what dEdts says, if you have two poles, one after the other, moving in the direction of their lengths, the space between them also contracts. "Length contraction" is a contraction of space, not just material objects.
OK thanks. Actually, I meant to say "length" contraction. But let's take the example of a rocket making a round trip to a nearby star at close to c. According to the rocket's clocks, maybe 50 years pass (I'm not doing math here, just giving a rough estimate), but back on Earth thousands of years have elapsed. My question is, in the length-contraction part of this journey, what exactly is seen as contracting? Obviously, it can't just be the rocket shrinking that causes all the duration difference, so I'm assuming that the lengths of space are also contracting. Or, is it just that the vast majority of the difference is due to time dilation? Thanks. Feel free to give a formula for the length contraction.
Ah, thanks Hallsoflvy, I didn't see your comment until after I posted my response above. I would still like to see the formula(s) that delineate which lengths/spaces are contracting and in what proportion these are to the time dilation.
HallsofIvy
Two points:
1) It's a fact that the intermolecular forces in a moving object are different than in a stationary object. Fitzgerald used this observation to predict length contraction. There's no reason to think that his derivation or reasoning were wrong, considering that he used Maxwell's equations to get his result and Maxwell's equations are Lorentz invariant.
2) If you have two poles separated by some distance, how the distance changes with time depends on how exactly you accelerate the two poles. It's possible to accelerate them so that the distance grows, shrinks, or stays the same.
dubiousraves
Let's analyze the rocket trip from two reference frames: the Earth's and the rocket's.
From the Earth's reference frame, the only thing that's shrinking is the rocket. The distance to the star does not change in the slightest. From the perspective of someone on Earth, the reason that the astronauts on the rocket think the trip only took 50 years is time dilation.
According to the theory of relativity, if a process at rest takes a time ##T## to complete, then the same process moving with speed ##v## will take a longer time to complete, namely ##\frac{T}{\sqrt{1-v^2/c^2}}##. This is known as time dilation, and explains why the astronauts would only think that 50 years elapsed: their clocks were slowed down!
From the astronaut's reference frame, it's the Earth and the star that are moving. Hence the distance between them contracts, which makes the journey that much shorter. That's the reason, from the astronaut's perspective, why the trip only took 50 years.
Thanks. I am aware of the time dilation equation. However, if you say the distance between the Earth and the star contracts from the astronaut's reference frame, is there not a formula that would express that exact contraction?
The formula for Length Contraction is the inverse of the one for Time Dilation, but those are just short-cuts that can get you into trouble. The equations that will never get you into trouble are called the Lorentz Transformation process. I like to use units for a simplified version of those equations where c has the value of 1, for example, 1 foot per nanosecond. I also like to express velocity as a fraction of c which we call beta and assign the Greek letter beta (β).
So let's say we have a rod of length 5 feet laying motionless along the x-axis. A spacetime diagram showing this simple scenario is:
Spacetime diagram with coordinate time in seconds on the vertical axis (-1 to 5) and coordinate distance in feet on the horizontal axis (-1 to 6). A blue vertical line sits at distance 0 and a red vertical line at distance 5, each spanning times 0 to 4.
The blue and red lines represent the two ends of the rod. The rod is spread out all along the space between it's two endpoints but we don't care about that, we only care about the endpoints that are used in determining its length. I'm only showing the positions of the endpoints for just a short time but we understand that the lines really extend upward and downward. Now let's see what happens if we transform the coordindates of this scenario into one that is moving at 0.6 toward the left. In this new diagram, the rod will be moving to the right at 0.6c and we can see how long it is.
The first thing we have to do when using the Lorentz Transformation is calculate the value of gamma, the Lorentz factor (the same value used to determine Time Dilation), as a function of β, in this case -0.6:
γ = 1/√(1-β2) = 1/√(1-(-0.6)2) = 1/√(1-0.36) = 1/√(0.64) = 1/0.8 = 1.25
Now we take the value of the t and x coordinates of each event (dot) in the diagram and calculate new values for the new diagram. The two equations for the new primed values are:
t' = γ(t-βx)
x' = γ(x-βt)
We can take another shortcut and just calculate the two endpoints of each of the two worldlines and fill in the extra events (dots) proportionally. So for the top of the blue line, x=0 and t=4:
t' = 1.25(4-(-0.6)*0) = 1.25(4) = 5
x' = 1.25(0-(-0.6)*4) = 1.25(2.4) = 3
For the bottom end of the blue line we have x=0 and t=0:
t' = 1.25(0-(-0.6)*0) = 1.25(0) = 0
x' = 1.25(0-(-0.6)*0) = 1.25(0) = 0
For the top of the red line we have x=5 and t=4:
t' = 1.25(4-(-0.6)*5) = 1.25(4+3) = 1.25(7) = 8.75
x' = 1.25(5-(-0.6)*4) = 1.25(5+2.4) = 1.25(7.4) = 9.25
For the bottom of the red line we have x=5 and t=0:
t' = 1.25(0-(-0.6)*5) = 1.25(3) = 3.75
x' = 1.25(5-(-0.6)*0) = 1.25(5) = 6.25
From those calculations and by interpolating (or by more calculations) we can make this diagram:
Spacetime diagram of two parallel worldlines, blue and red, plotted as coordinate time in nsecs against coordinate distance in feet, with both lines sloping upward to the right.
Now it's important to know that when we want to determine the length of an object (or the space between objects), we have to do it along a line where time is constant. So look at the horizontal grid line where time is 5 nanoseconds. The top of the blue line is on that grid line at x=3 feet and immediately to its right is the second dot up on the red line with an x coordinate value of 7 feet. The difference between these to events (dots) is 4 feet. This is the contracted length of the rod from its Proper Length in its rest frame divided by gamma (5/1.25=4).
You can also see the Time Dilation in this diagram where the dots representing 1 nsec intervals of time in the rest frame of the rod are now stretched out to 1.25 nsec of Coordinate Time.
The other important feature of Special Relativity call Relativity of Simultaneity is also shown where events that were simultaneous in the first frame occur at different times in the transformed frame.
  • Spacetime diagram with coordinate time in seconds on the vertical axis and coordinate distance in feet on the horizontal axis. A vertical blue line at distance 0 and a vertical red line at distance 5 each span times 0 to 4, showing two motionless endpoints of a rod.
  • Spacetime diagram plotting coordinate time in nsecs against coordinate distance in feet; a blue line runs from (0, 0) to (3, 5) and a parallel red line from about (6.3, 3.7) to (9.3, 8.7).
He didn't have the slightest idea what he was doing, pure guesswork. Working in 1890, Lorentz knew nothing of Quantum Mechanics or the nature of intermolecular forces or what actually determines the size of an object.
Thanks for that elegant explanation, GHWellsJr., but I'm still wondering if the the space AROUND a moving objects contracts.
Is space itself ever measured? Or is it the length between points
I don't think that's fair. True, his derivation was based on a simplified and classical model, but so was all of 19th century physics. Do we begrudge Clausius and Maxwell of their kinetic theory of gases because it used a simplified and classical model?
There is no such model, and Lorentz did not pretend to have one. You can't build a solid object out of Maxwell's Equations.
How would you explain in classical terms the Lorentz contraction of a gas?
I did try to hint at that when I said, "...when we want to determine the length of an object (or the space between objects)...", so the answer is yes. The blue and red lines can represent either the two ends of a single object or two separate objects, it doesn't matter.
But remember, length (or distance) contraction is merely a coordinate effect. When we change reference frames and use the Lorentz Transformation process, the time and length (or distance) coordinates change. Nothing has actually changed to the objects or the space. The same can be said for Time Dilation.
Observers in a scenario cannot tell that we switched to a different reference frame when we did the above exercise and so nothing changes either in what they see, what they measure, or what they observe. In fact, Length Contraction and Time Dilation are completely unobserverable. They can only be determined by observers by proactively sending out radar signals, waiting for their echoes, observing clocks on other objects, logging all the data and the times they occurred according to their own clock and then doing a lot of computation. Only after the entire scenario is over will they be able to go back and make diagrams like I did and see those coordinate effects.
If you assume that intermolecular forces are electrical in nature then you can deduce, based on how the electric field of a moving point charge compares to a stationary charge, that the size of molecules as well as the intermolecular distance will shrink by a factor of gamma. I won't pretend that this is a precise derivation or anything (and as you mention, a precise derivation is classically impossible because classical physics does not permit the existence of solid bodies), but nonetheless my original point sill stands: contrary to what HallsofIvy stated, the contraction of a moving body is ultimately due to the behavior of the forces holding that body together, whether or not it's practically feasible to calculate length contraction by analyzing these forces. Special relativity doesn't change this fact. It only allows us to efficiently calculate what the length contraction will be without having to analyze, say, intermolecular forces.
As for the length contraction of a box of gas, the explanation is the same as for a rod: the box containing the gas will contract because of the behavior of the forces holding the box together.
This entire discussion is going to lead down a road that has already seen blow after blow after blow in the past. Some people try to separate length contraction into two classes: the Lorentz contraction obtained from boosting between inertial frames, which these people would label a "coordinate artifact" and the Lorentz-Fitzgerald contraction which is what you are referring to and which said people would label a "real effect". Therefore these people would qualify Lorentz contraction as a different phenomenon from Lorentz-Fitzgerald contraction. Others would argue that they are not different phenomena but rather just different "components" of the length contraction relativized to a given observer (which is, IMO, the better viewpoint). With that terminological issue out of the way, it should be clear now that neither your posts nor those of others in this thread have encompassed both "components" of length contraction. Everyone is speaking past one another by exclusively referring to one or the other.
An analysis of the Ehrenfest paradox should help your conceptual understanding of the bridging of the two.
WannabeNewton said:
This entire discussion is going to lead down a road that has already seen blow after blow after blow in the past. . .
At the risk of bringing blows down upon myself, can I ask some questions to clarify the two views?
Consider the basic barn and pole paradox, where the barn has a front door and a solid rear wall. A pole has greater proper length than the proper length of the barn; the pole and barn are in inertial motion with respect to each other; in the barn frame, the pole is length contracted and enters the barn through the front door; the door closes, and the pole is entirely within the barn (at least for a very short period of time in the barn frame).
dEdt and ghwellsjr, do you each agree that the pole is entirely within the barn in the barn frame for at least a short period of barn time?
dEdt: if yes, does this occur only if the rod is in absolute motion (such that its molecules are contracted due to the behavior of the forces holding the rod together), or do you conclude that there is a behavior of forces on the rod regardless of whether the rod had been accelerated, the barn had been accelerated, or even if one does not know which one was accelerated (given that we are told that there is no absolute motion in inertial motion)?
ghwellsjr: if yes, what do you mean by the rod's length contraction being merely a coordinate effect, or as WannabeNewton states a "coordinate artifact"? If the rod is contracted and fits in the barn in the barn's frame, isn't its length contractedness in the barn frame a "real effect," using WBN's phrase?
Yes, absolutely.
I'm not 100% sure I understand your question, but I'll answer as best as I can.
Let's say we're in the barn frame and happen to see a rod flying past us. We don't know how the rod reached that speed -- maybe it was traveling that way for its entire existence, maybe it was recently accelerated to that speed, maybe it was traveling even faster in the past and recently decelerated -- nor do we care. Further suppose we have the divine knowledge that the same rod would have a length ##L## along the direction of motion if it were stationary. Then, necessarily, the length of the rod will be ##L\sqrt{1-\beta^2}## in the barn frame.
No one gets blows for asking questions here.
That's not the basic barn and pole paradox because it doesn't have a back door which opens at just the right time to let the pole out unharmed. Nevertheless, we can deal with either type of situation.
Yes.
No, it's based on the convention of simultaneity. Conventions are man-made concepts. What's real is the fact that the pole will smash into the rear of the barn and explode it unless something is done to stop it. If you do stop it, the other issue of "contractedness" comes into play.
I have thoroughly analyzed and presented both flavors of this paradox in these two threads. Please study them and see if they answer your questions.
https://www.physicsforums.com/showthread.php?p=4409852
Make sure you read my two posts on the first page of the above thread.
https://www.physicsforums.com/showthread.php?p=4544441
dEdt said:
. . . Let's say we're in the barn frame and happen to see a rod flying past us. We don't know how the rod reached that speed -- maybe it was traveling that way for its entire existence, maybe it was recently accelerated to that speed, maybe it was traveling even faster in the past and recently decelerated -- nor do we care. Further suppose we have the divine knowledge that the same rod would have a length ##L## along the direction of motion if it were stationary. Then, necessarily, the length of the rod will be ##L\sqrt{1-\beta^2}## in the barn frame.
This answer assumes that it is the rod that was accelerated and is moving, which is consistent with your earlier posts, which depend upon physical effects from the object moving:
It's a fact that the intermolecular forces in a moving object are different than in a stationary object. Fitzgerald used this observation to predict length contraction." (post 6), and
If you assume that intermolecular forces are electrical in nature then you can deduce, based on how the electric field of a moving point charge compares to a stationary charge, that the size of molecules as well as the intermolecular distance will shrink by a factor of gamma. . . [T]he contraction of a moving body is ultimately due to the behavior of the forces holding that body together, whether or not it's practically feasible to calculate length contraction by analyzing these forces. (post 15)​
But what if the barn had been accelerated? That may seem impractical, so consider a bay in a spaceship. The spaceship could have been accelerated, and a rod floating in outer space would still present length contracted and still fit within the bay as the bay door closes. No forces acted on the rod; all acted on the spaceship.
Perhaps we are speaking past each other. When I say "the pole is entirely within the barn in the barn's frame" I mean that the pole is in the barn before any collision with the barn's rear wall, or before any clamping of the pole (as discussed in the posts that ghwellsjr linked). Just for the brief time after the door closes and before the pole crashes into the back wall, the pole (in its entirety) is inside the barn (is entirely enclosed by the barn) in the barn frame. This occurs because the length of the pole is shorter in the barn frame than in the pole's frame. The pole is already length contracted before any crashing or clamping.
Yet this can occur without any acceleration of the pole, and thus without any forces acting on the molecules of the pole. So I do not understand how the length contraction can be said to occur because of forces on the pole's molecules.
Let's look at the version in which the pole does not burst through the rear wall. I agree generally with your linked diagrams, but I think that there is still a definitional issue about what is "coordinate" versus "real."
Say that the pole is balsa wood, and it enters a cave in an extremely dense mountain, and a door at the mouth of the cave closes. Where your explanation confuses me is in this part of your post 2 in the first link:
if you actually stop the ladder by simultaneously (in the garage frame) forcing each portion of the ladder to stop and stay stopped, then it will end up being shortened. Of course, as they point out later in the article, there's no such thing as a truly rigid ladder and so we have to imagine that this ladder can deform by whatever mechanism caused it to stop.​
As I understand SR, the rod/pole/ladder is already length contracted in the barn/cave when the door closes. The rod is entirely contained in the barn, which can only occur because its length in the barn frame is shorter than the length of the barn (in the barn frame). Clamping the rod does not cause it to "end up being shortened" in the barn frame. It is already length contracted in the barn frame.
Stopping the rod as described only causes the rod to end up shortened in its own frame after it finishes deforming. Even without clamps, the balsa wood pole might simply crash into and be compressed against the rear wall of the cave; or it might crash, compress, then partially expand back toward the door. But it could stay entirely within the cave, although obviously deformed as you mention. And in the cave frame, the pole is within the cave both immediately before it crashes and after it crashes.
Clearly this is not the case in the pole frame. But that is irrelevant. The relativity of simultaneity allows for both of the frames to be equally valid, so it is just as valid for a cave dweller to conclude that the balsa wood pole is "really" entirely within the cave before the crash as it is for a pole rider to conclude that it "really" is not. It seems to devalue the cave frame to say that the length of the pole in the cave frame is not real.
In the barn's reference frame, the rod accelerates. As it accelerates the intermolecular forces change, causing it to shrink.
Edit: I'll try to anticipate your next question.
Suppose that we had a spaceship floating in space (where else?) measuring the distance between two stars 4 light-years apart. The spaceship then applies its thrusters, causing the interstellar distance to decrease. From the spaceship's perspective, what's responsible for the change in distance? Surely not "changes in interstellar forces", right?
This example illustrates the difficulties with analyzing things in non-inertial coordinate systems (at least in special relativity). Just as in classical physics, a relativistic non-inertial observer can understand some but not all of the phenomena he witnesses because the laws of physics are simply not the same in his reference frame. From the spaceship's perspective, the observed reduction in interstellar distance can only be explained by analyzing the situation from an inertial reference frame.
But as soon as the spaceship ceases to accelerate, astronauts on board have no difficulty explaining why the distance between the two stars is only 1 light-year -- that's the actual distance, in their reference frame! The only thing that requires explanation is why Earth-based astronauts would disagree and instead conclude that the distance is 4 light-years, and that can be explained by the distortions in their telescopes and other measuring apparatuses due to their motion.
I like the way you continually state "in the barn/cave frame" when discussing issues of time and length. That's very important. But we cannot simply say the rod/pole/ladder frame because it is at rest in two different inertial frames. We can use that terminology for the normal version of the paradox where the object remains inertial, but in this version we have to say something like the rest frame of the pole/rod/ladder prior to its being clamped to a stop.
Besides that issue, right at the end, you equate a frame with an observer when you refer to the "cave dweller" or the "pole rider" as if what the cave frame depicts is what's real for the cave dweller or what the pole frame depicts is what's real for the pole rider. This was my fifth objection in post #5 of the linked thread that you are talking about:
ghwellsjr said:
5) In their explanation for Figure 8 they repeatedly use the words "sees", "see" and "seen" and apply it to a person, which is incorrect. No person anywhere in any scenario can see what is depicted in a spacetime diagram unless light signals are also drawn in. They did not draw them in any of their diagrams. If you do drawn them in, it won't matter which frame you use, they all will show the same thing for what any observer sees.
What the pole or ladder rider sees is what's real. What the cave or barn dweller sees is what's real. If we were to go to the effort of drawing in 45-degree lines from various events to the locations of these observers, we would see that it doesn't matter what frame we do it in. They cannot tell just by observations what the frames depict. That means that they cannot observe length contraction and the only way they can determine the length contraction that a particular frame depicts is if they actually send out and receive radar signals and assume that the signals take the same amount of time going as coming to determine a distance and assign that distance to the average of the sent and received time, then they can make a diagram of their individual rest frame. For an inertial observer like the barn dweller, he will end up with the same diagram as the one I already drew for the rest frame of the barn and he can transform to any other inertial frame. But for the ladder rider, depending on where he is on the ladder, he will get a different diagram than any portion of either of the two diagrams that I drew. This is because he is non-inertial and his rest frame is going to be non-inertial. But he can then use that information and the knowledge that the barn is inertial to construct the same diagram that the barn dweller made and from there he can transform to any other inertial frame. The barn dweller can also derive the non-inertial frame of the ladder rider.
So none of these diagrams depicts anything more real than any other and since length contraction is different in each one, it cannot be said to be real. But all the diagrams depict what is actually real for any observer, namely, what they can actually see and measure.
ghwellsjr said:
...But remember, length (or distance) contraction is merely a coordinate effect. When we change reference frames and use the Lorentz Transformation process, the time and length (or distance) coordinates change. Nothing has actually changed to the objects or the space. The same can be said for Time Dilation.
Indeed I like this. Do you agree that “we” does not stand for “the observer” (I mean anybody involved in the experiment and who receives physical signals) but “we physicists who formalize the physical scenario” (I mean a theoretician who is not necessarily involved in the experiment)? Just remember the “moving magnet and conductor” experiment described by Einstein: nowhere he needs to specify where the “observer” stands, it's enough to know that the device which measures the intensity of the current (the physical quantity which gets “observed”) is tied to the conductor.
The former Newtonian mechanics did not enforce such a change in the formal description of the world. It did not impose that physical quantities such as the spatial length and the time duration separating two physical events be assigned different numerical values, via the Lorentz transformation, depending on the IRF selected by the theoretician to represent the coordinates of those events. Hence it did not impose homogeneous descriptions of the world whereby the relevant physical quantities must be defined in respect to the same IRF. For example the thickness of the atmosphere is usually defined in the rest frame of the Earth, whereas the lifetime of a muon is defined in its own rest frame. On that basis the former Newtonian mechanics could not explain that a fast-enough muon can reach the ground before decaying. Only the SR theory, because it imposes to relate the numerical value of physical quantities to the same IRF, whichever one is selected, is able to predict that outcome, irrespective of the selected IRF: a fast-enough muon can reach the ground. Please note that no reference is made to any kind of “observer”.
IMHO the "barn and ladder" scenario should be discussed in the same way: should their respective length be related to the same IRF, whichever is selected, a fast-enough ladder would entirely fit in the barn. Is this correct?
Do you agree that “we” refers to the theoretician who analyze a unique scenario through different formal representations (different IRFs), whereas “they” stands for the “observer(s)” who is (are) involved in this unique scenario through performing measurements or observations (and who therefore must receive enabling signals)?
Nothing changes in the observable world due to the decision by the theoretician to describe the same scenario alongside a different framework. Changing IRF does not trigger any physical effect, and this is why no change can be “observed”. Your diagrams perfectly illustrate that the propagation of signals toward the “observer” overlays the SR-induced description of the world with 45° lines representing light rays and entails a Doppler effect which affects the outcome of “observations” through a genuine physical (Doppler) effect. Unfortunately most debates about SR fail to clearly distinguish both layers and misuse the words “see”, “observe” or “measure”.
dEdt and ghwellsjr, thanks. These are certainly very different approaches; it will be interesting to think more about whether they are distinct, or rather different components relativized to a given observer as WannabeNewton suggests.
The two approaches are closely related, and I'll outline how but first I need to make an important point.
Again consider a rod moving in an inertial reference frame. Some people in this thread seem to deny that it is possible to use the laws of physics (as expressed in this reference frame) to deduce that the rod will contract without performing any coordinate transformations. These people are simply wrong. To see why, consider a simpler system: a hydrogen atom in its ground state. If this atom is at rest, it is a simple undergrad-level application of quantum mechanics to calculate the size of the electron orbital. If the atom is moving, while the calculation would become much more involved it is still possible in principle to deduce the new size of its electron orbital. Anyone who argues otherwise is, in effect, arguing that the laws of physics don't apply to objects in motion. And as we all know, we would find that the electron orbital is compressed along the direction of motion compared to the electron orbital at rest. What's true for a hydrogen atom is true for a measuring rod or any other system imaginable.
So, what's the relationship between the physical contraction of a moving rod and coordinate transformations?
While it's possible to calculate the size of a moving rod in the reference frame where it is moving, such an endeavor would obviously be foolish because it would involve probably the most difficult calculation in condensed matter physics ever undertaken. Thankfully there's a simpler way: we exploit the Principle of Relativity.
The Principle of Relativity asserts that there exists a new coordinate system where 1) the rod is at rest, and 2) the laws of physics are the same. This is fantastic because in this new coordinate system we don't need to calculate the length of the rod! We already know it has to be ##L##, the rest length of the rod in the original reference frame, because the laws of physics are the same. So in order to find the length of the rod in the original frame, we just apply a coordinate transformation back to the original coordinate system. And thankfully Einstein already deduced what coordinate transformations preserve the laws of physics: these are just the Lorentz transformations. So by applying a Lorentz transformation back to the original coordinate system, we find that the length of the rod is ##L\sqrt{1-\beta^2}##.
This second approach does not deny that the rod contracts because of the behavior of its intermolecular forces. Rather, it sidesteps having to work out the details of how these forces change when the rod moves by exploiting the fact the laws governing the intermolecular forces (quantum electrodynamics) are invariant under a Lorentz transformation.
Yes, when I said "we", I meant all of us that are defining, describing, analyzing, and discussing a thought experiment. We imagine observers experiencing the thought experiment.
In the barn frame, yes. I hope the two threads I pointed to in post #20 made that very clear.
Yes, but I also pointed out that any observer can also be a theoretician, assuming that we let them perform the relevant experiments.
How true.
This is what Lorentz was forced to assume, and why his viewpoint lost out to Einstein's. All Lorentz really had to go on was the fact that a moving Coulomb field appears contracted. But the world is made of other things besides electromagnetism. The shape of planetary orbits for example is determined by Newtonian gravity. How does Newtonian gravity transform under a velocity boost? We now know that gravity does NOT transform the same way as electromagnetism.
And the shape of nuclei (or neutron stars) must change exactly the same way too. But even without knowing of the existence or nature of the nuclear force, Lorentz had to hypothesize that all forces underwent an identical contraction. Einstein of course replaced this ad hoc assumption with the much simpler idea that space itself was responsible.
What clinched the argument in Einstein's favor was the realization that relativity applied to particle kinematics as well, which Lorentz's theory did not.
Suppose we have three mobile laboratories and in one there is an instrument with a digital readout measuring a rod. The other two labs speed off and use some method to measure the rod (in the first lab) themselves . They find that their measurements give a smaller number than the digital readout which they can also see.
All measurements are made when the 3 labs are moving inertially. Did the rod experience any strain or change in molecular configuration because the other two labs made a measurement ?
If the two labs made their remote measurements so that they were simultaneous in the rod frame, how did the rod sustain two different states at the same time ?
