Functional equation with reciprocal and power scaling
  • Level: Graduate
  • Thread starter Thread starter Beerdrinker
    Type
4 replies · 2K views
Beerdrinker
Hi,
I am struggling with a problem, where in the middle of my calculations I need to determine a function ##f(\alpha, \beta; x)##, namely the function of ##x## parametrized by ##\alpha## and ##\beta##, from the following equation
$$f\left(\alpha, \beta;\frac{1}{x}\right) = x^4f(\gamma, \delta; x).$$
So the ##f(1/x)## on the LHS and ##f(x)## on the RHS may differ in parametrization. Somehow I found that this equation admits the following solution
$$f(\alpha, \beta; x) = \left(\alpha + \beta x^a\right)^b $$
where ##a\cdot b = -4##. Although, this is probably not the most general solution.
So my question is what type of equation this one is? And how one should approach such equation?
Some clarifying questions:
Is x a non-zero real number?
Are [itex]\alpha, \beta[/itex] real numbers?
Are [itex]\gamma[/itex] and [itex]\delta[/itex] real number constants (independent of [itex]\alpha, \beta, x[/itex])?
In your example, you're assuming [itex]\gamma = \alpha = \delta = \beta[/itex]?
##f(x)## is well defined and restricted to either ##x>0## or ##x<0##.
##\alpha##, ##\beta##, ##\gamma##, ##\delta## in general may be complex and independent of ##x## (they parametrize function ##f(x)##).
However ##\gamma##, ##\delta## may be functions of ##\alpha##, ##\beta##.
In the example I provided previously we have
$$f\left(\alpha, \beta; x\right) = \left(\alpha + \beta x^{a} \right)^b \Rightarrow f\left(\alpha, \beta; \frac{1}{x}\right) = \left(\alpha + \beta x^{-a} \right)^b = x^{-ab}\left(\alpha x^a + \beta\right)^b = x^{4}f(\beta, \alpha; x)$$
Where the assumption ##ab = -4## was used. So in this case ##\alpha = \delta## and ##\beta = \gamma## and are not neccesarily equal.
Sorry for not making this clear enough earlier.
