alijan kk
- 130
- 5
Really?.Scott said:The domain is defined as -0.5 to +0.5.
The resulting range is -0.4 to +0.5.
.Scott said:I believe it is injective but not surjective.
So every value in the domain yields a unique value in the range (injective).
But there are some values in the potential range (-0.5 to -0.4 and 0.4 to 0.5) which are not used.
I fixed it.DrClaude said:Really?
the B set isDrClaude said:No, still wrong. But please let the OP answer now (this is the homework forum).
it is not ijective because, the range is not a subset ! "serjective but not injective" should be correct ? and serjective has range=B [-0.5,0.5]DrClaude said:But is it one-to-one? Do you get a unique value for each ##x## in the domain of ##f##?
You should also check if it is surjective or not.
What is "MCQS"?alijan kk said:MCQS is in the image
Noted...DrClaude said:But please let the OP answer now (this is the homework forum).
multiple choice questionMark44 said:Noted...
it is therefore requested kindly give me a hint or tell me the answerMark44 said:Noted...
Post #3 is a hint. A graph of this function would be helpful.alijan kk said:it is therefore requested kindly give me a hint or tell me the answer
domain is all real numbers,, and range is [-0.5,0.5]Mark44 said:Post #3 is a hint. A graph of this function would be helpful.
By forum rules, we can steer you in the right direction, but we can't just tell you the answer.
If you solve the equation ##y = \frac 1 {1 + x^2}## for x, do you get a single value of x for each y value? If so, the original function is invertible, and therefore one-to-one (i.e., injective).alijan kk said:domain is all real numbers,, and range is [-0.5,0.5]
Your thread would be improved if you were to display the image, rather than just showing the thumb-nail.alijan kk said:Homework Statement
MCQS is in the image,
as the range of this function is the subset of B , it is an injective function ?
option one is correct ?
