What would be the most efficient 1kw motor to use at low RPM
  • Thread starter Thread starter Fizzics
    Motor Rpm
The most efficient 1 kW motor for low RPM applications is a three-phase brushless motor, which can achieve efficiencies up to 98%. In contrast, single-phase motors are less efficient, with full load efficiencies ranging from 85% to 97%. Motor losses are categorized into friction and windage (5%-15%), iron or core losses (15%-25%), stator losses (25%-40%), rotor losses (15%-25%), and stray load losses (10%-20%). Regulatory bodies are increasingly mandating the use of premium-efficiency induction motors to promote energy efficiency.
  • Understanding of three-phase motor technology
  • Knowledge of motor efficiency metrics
  • Familiarity with energy efficiency regulations
  • Basic principles of brushless motor design
  • Research the design principles of brushless motors
  • Explore the impact of motor losses on efficiency
  • Investigate current energy efficiency regulations for electric motors
  • Learn about premium-efficiency induction motors and their applications
Electrical engineers, motor design specialists, energy efficiency consultants, and anyone involved in selecting or optimizing electric motors for low RPM applications.
Fizzics
...Up to 300 rpm (3 phase motor) and what sort of efficiency could I expect under normal conditions with a small load? Thanks
Fizzics said:
...Up to 300 rpm and what sort of efficiency could I expect under normal conditions with a small load? Thanks
I assume you're talking a single phase motor. Too bad, three phase motors are more efficient.https://en.wikipedia.org/wiki/Induction_motor#Efficiency
wiki said:
Full load motor efficiency varies from about 85% to 97%, related motor losses being broken down roughly as follows:[39]
  • Friction and windage, 5% – 15%
  • Iron or core losses, 15% – 25%
  • Stator losses, 25% – 40%
  • Rotor losses, 15% – 25%
  • Stray load losses, 10% – 20%.
Various regulatory authorities in many countries have introduced and implemented legislation to encourage the manufacture and use of higher efficiency electric motors. There is existing and forthcoming legislation regarding the future mandatory use of premium-efficiency induction-type motors in defined equipment. For more information, see: Premium efficiency and https://en.wikipedia.org/w/index.php?title=Copper_in_energy_efficient_motors&action=edit&redlink=1 .
Thanks for your reply - actually i meant to say that it is 3 phase
With a brushless motor, 98% efficiency is not unheard of. It can be designed so that max efficiency operating point of the motor matches the mechanical load.
  • · Replies 74 ·
9K
