What's the best way to separate a dissolved mixture
  • Thread starter Thread starter Kombaiyashii
    Mixture
The discussion centers on effective methods for separating sodium bicarbonate from water to achieve a dry powder. The user initially employs low-heat evaporation in a baking dish but encounters issues with crystallization and moisture retention. Forum members suggest maintaining a temperature below boiling, using a dehydrator for efficient drying, and incorporating mixing or crushing to enhance moisture removal. A lid is discouraged as it traps vapor, hindering the drying process.
  • Understanding of sodium bicarbonate properties and behavior in solution
  • Familiarity with evaporation techniques and temperature control
  • Knowledge of dehydrators and their applications in drying
  • Basic skills in handling laboratory or kitchen equipment safely
  • Research the use of dehydrators for drying chemical solutions
  • Learn about the principles of evaporation and boiling point management
  • Explore methods for preventing crystallization during drying processes
  • Investigate alternative drying techniques such as vacuum drying
This discussion is beneficial for hobbyists recreating historical medicines, chemists experimenting with solubility, and anyone interested in efficient drying techniques for chemical compounds.
Kombaiyashii
Hi folks,
I like to recreate medival medicines from old manuscripts but I have come to a slight problem when it comes to the prepairation...
I'm trying to separate sodium bicarbonate which is dissolved in water. What I usually do is have a baking dish like the one below filled with the solution of water and sodium bicarbonate...I then put it in the oven on a low heat. After a while the water evaporates leaving mostly the sodium bicarbonate in the dish...
http://iweb.cooking.com/images/products/enlarge/183013e.jpg
The problems is that I can't get it very dry. I would like to evaporate all the water so I get a 100% powdered solution. If I carry on heating the solution, eventually the sodium bicarbonate crystalises which traps some water underneath and the crystals heat up and the whole thing starts spitting and then I get sodium bicarbonate all over my oven...
I was wondering if anyone knew a better way to separate the two and get a nice dry powder without too much work or expensive equipment?
Thanks,
Komb
Chemistry news on Phys.org
Seems to me your solution should work OK if you just keep the temp below boiling and let it simmer long enough.
Or you could just put a lid on the pan. Does it matter whether your precipitate is collected in the pan or on the underside of a lid?
@OP, do you have access to a dehydrator (usually used to dry fruits and vegetables)? Very little monitoring is necessary, and you can use the various trays to dry several solutions at once, if you like.
Many hours at temp below boiling, that's more or less the standard procedure.
Some mixing/crushing during drying won't hurt - you will break the surface and allow water to escape.
Lid will slow the process, you want the vapor to be able to leave the volume above the salt, as salt will be not drying under saturated atmosphere.
Right. A screen then.
I came.across a headline and read some of the article, so I was curious. Scientists discover that gold is a 'reactive metal' by accidentally creating a new material in the lab https://www.earth.com/news/discovery-that-gold-is-reactive-metal-by-creating-gold-hydride-in-lab-experiment/ From SLAC - A SLAC team unexpectedly formed gold hydride in an experiment that could pave the way for studying materials under extreme conditions like those found inside certain planets and stars undergoing...
14K
