What's the volume of water required inside the lock if
  • Thread starter Thread starter davekardle
    Lock Volume Water
The discussion revolves around calculating the volume of water required inside a lock given specific dimensions and the weight of a ship with a load. The problem involves concepts from fluid mechanics, particularly Archimedes' principle and the displacement of water by the ship and its cargo.
  • Mixed
  • Participants explore the calculation of water volume needed to prevent grounding and the implications of the ship unloading its cargo. Questions arise regarding the interpretation of "volume of water required" and the effects of oil being emptied into the lock.
The discussion is ongoing, with participants providing insights and questioning the assumptions made about the ship's load and the mechanics of water displacement. Some suggest considering different models of the ship's hull and its interaction with the water and oil.
There are uncertainties regarding the exact nature of the load (oil) and its density, as well as the geometry of the ship, which complicates the calculations. Participants express confusion about how to proceed with the calculations after the load is emptied into the lock.
davekardle
What's the volume of water required inside the lock if...
The dimension of the lock is:40 long x 3.5 height x 6 width
allowing 0.5 height.
The ship weights 400T plus 300T(LOAD)
total= 700T
whats the amount of water used per lock allowing allowing 0.5 m from the height?
What if the ship empties its load on the lock ? the density of the load is 755kg/m^3.
2. Homework Equations
Archimedes principle
Mass of water displaced
3. The Attempt at a Solution
Mass of water displaced by the boat mass = 700T
VOLUME = 700M^3
Total volume inside the lock allowing 0.5
(3x40x6)m^3 - 700M^3
Is that correct ?
How about if the ship empties its load on the lock ?
You could just repeat the calculation without the load, but I'm not sure what is meant by "the volume of water required" Required to do what? To keep the lock full? To keep the ship from grounding?
But how do I repeat the calculation?
the ship is 400T heavy without the oil
The amount of oil displaced by the **** is greater than the actual oil it emptied into the lock.
I don't know how to proceed
You didn't mention oil before, and when you wrote 'empties its load on the lock' I took that to mean merely that it unloaded whilst in the lock. Are you saying now the load is oil and it pours that into the lock, Exxon-style? If so, might need the density of the oil.
(Have you provided the question verbatim? If not, please do so. I get the feeling I'm missing some detail.)
Hey sorry, I forgot to mention some of the details yes.
The ship average displacement is 400T + 300t ( load = oil C10H22)
Oil density is 730 mg mL−1.
The ship suffers a hull fracture and empties its load (oil ) into the moving lock.
The lock dimension is: 40 long x 6 width x 3.5 height
Allowing 0.5m of the height for the water level.
So I worked out I only needed 20m^3 of water to prevent the ship grounding.
but I'm not sure how to proceed with the calculation after the load is emptied into the lock.
300T of the oil =~ 400m^3
Does the lock overflow ? what happens? I'm so lost.
If the fracture is below the water line, won't the water flow into replace lost oil, leading to the ship's foundering? If we ignore that, presumably it will stop flowing out when ... what do you think?
Thinking about this more, I don't think the question is well posed. Depends too much on details of the geometry of the ship and its cargo.
Model 1: simple hull, filled with oil from bottom up. Oil occupies ~400m3, ship+oil displaces 700m3, so 300m3 space above oil is below water line. If holed, water flows in, not oil out (until it sinks).
Model 2: Some combination of ballast and air compartments manages to lift the oil completely above the water line (somehow without tipping over). Holed in that elevated section, the oil can now flow out. But where will the oil/water boundary in the lock be in relation to the ship? Let Vw be the volume of the hull below the water line and Vo be the volume above water but below oil surface. Let ρw, ρo be the respective densities. So Vwρw+Voρo = 400T. I believe the volumes depend on hull geometry, but you could try assuming the hull is a simple box of horizontal area A and see if you can deduce anything.
Thanks for the input buddy. I think the second option is what my lecturers are really looking to see in our assumptions while doing this project. Assuming that the hull is a simple box where would the layer between oil and liquid lie ? I am trying to design a way to drain the lock up to a point where around 90% of the oil is recovered. Do you think that by removing the ship and then inserting a pipe to the lock lateral at a height where the oil/water boundary lies and then draining out all the oil layer is a good option for recovery?
Create some variables for the knowns and unknowns, like horizontal cross-sectional area of the hull, depth of hull in water, depth of hull in oil, etc. and see what equations you can come up with.
Do you mean removing the ship physically? How will you do that without losing the oil?
