per persson said:
Above is the pages of the problems. T is the force caused by a cable.
I'm still lost on how to determine if there is reactive moment or not when there are more than two supports.
The text you highlight doesn’t say there is no reactive moment, it says there need not be one. It is an example of static indeterminacy. A simple example is a table with four legs. If we take the idealised view that the legs are exactly equal in length and perfectly rigid, and the floor perfectly flat and rigid, there is no way to determine how much weight each leg is taking. In reality, tiny deviations from the idealisation lead to the actual forces.
In these torque examples, if there is a combination of forces at the joints which produces equilibrium then perhaps there are no torques at the joints, but if the joints are capable of producing torques then it could be that there are torques and the forces are in some other combination.
For example, a simple horizontal beam fixed by rigid joints at the ends. Either one of the joints can produce equilibrium by itself, meaning there need not be any force or torque from the other.
per persson said:
If I understand your method right you find an axis where reactive forces of two supports do not cause a torque about it.
Or more, if possible.
per persson said:
Then u look at other forces which do cause a torque about this axis and say those forces prevent any rotation around the axis
That they
can prevent rotation. To be sure they will, they have to be constraint forces, i.e. forces that adjust as necessary to inhibit movement. Merely hanging a weight on one side, for example, might not do it.
Indeed, a non constraint force might be precisely what does cause rotation.
per persson said:
and thus there is no reactive moment of the supports around an axis parallel to this axis.
There need not be a reactive moment around such an axis.
per persson said:
I don't understand this. How do we know that the forces that cause a torque around the axis are enough to prevent rotation, if the forces are not enough a reactive moment could be introduced to prevent rotation.
Answered above. For example, an object weight W resting on the floor. The normal force from the floor is a constraint force, adjusting to be the minimum force to prevent the object from penetrating the floor.
per persson said:
Also how do we conclude that the supports cause no reactive moments by looking at some random axis?
The procedure as you describe it above only shows there
need not be a reactive moment about the
chosen axis. Consider a beam suspended by two parallel rods. Take a vertical axis along one rod. If we add a constraint holding the centre of the beam in position, but not restricting rotation in the horizontal plane, it can exert a torque about the axis, but if the rods do not then rotation about that axis possible.
Had we chosen a vertical axis through the centre of the beam we would have discovered that the added constraint does not prevent rotation.
