When does potential energy change?
The discussion revolves around the conditions under which the potential energy of a substance changes, particularly in relation to pressure changes. Participants explore this concept in the context of different substances, including gases and solids, and consider theoretical and practical implications.
  • Some participants question why the potential energy of a substance does not change with pressure changes, seeking clarification on specific cases where it might change.
  • Others propose that potential energy can change if external pressure deforms a substance, suggesting that work done in deformation can be considered as a change in potential energy.
  • A participant introduces the behavior of gases, noting that the relationship between pressure changes and energy is well analyzed through pressure-volume-temperature relations, but potential energy is not well defined due to the constant motion of gas molecules.
  • Some participants discuss the kinetic theory of gases, emphasizing that the average kinetic energy of gas particles is dependent on absolute temperature, and that potential energy changes are negligible in ideal gases.
  • There is a suggestion that real gases exhibit potential energy changes due to closer particle packing, contrasting with ideal gas behavior.
  • A participant raises a question about the internal energy of a fixed mass of gas when volume increases, pondering the relationship between internal kinetic energy and potential energy under constant internal energy conditions.
  • Another participant notes that potential energy can be thought of as the energy of configuration, which changes with displacement or volume changes.
Participants express multiple competing views regarding the relationship between pressure changes and potential energy, particularly in the context of different substances. The discussion remains unresolved, with no consensus on the conditions under which potential energy changes.
Participants reference various assumptions about ideal and real gases, the role of kinetic energy versus potential energy in internal energy, and the definitions of potential energy in different contexts. These factors contribute to the complexity of the discussion.
Angela Liang
Why doesn't the potential energy of a substance change when the pressure changes? Or in what case will the potential energy of a substance change?
pl.elaborate about your substance...is it a body or a system of particle or a liquid.?
if the external pressure has deformed it and the work done in deformation can be accounted for as capacity of the body to do mechanical work then the potential energy does change by applying pressure.
a common example is a spring of length l and one changes its length to say l-dl !
How about gas in an enclosed system?
for gas as substance the relation with pressure changes is well anaysed using p, v, t relations and the energy of the system is related to temperature and work -energy theorems deal with it...gas molecules are in incessant motion and a state of potential energy is not well defined.
Thanks. How to describe it using kinetic model of matter?
Kinetic theory is based on the postulates,/ assumptions like gases are composed of a large number of particles that behave like hard, spherical objects in a state of constant, random motion.
These particles move in a straight line until they collide with another particle or the walls of the container. the collisions are perfectly elastic
the interaction between them is during collision
The average kinetic energy of the gas particles depends only on the absolute temperature of the system.
you can see the details in any textbook of physics.
If you've been told that PE doesn't change you've been dealing with a theoretical gas called an ideal gas where any changes of PE are considered to be negligibly small. No gas is perfectly ideal but they approach ideal behaviour as the pressure approaches zero, in other words for very largeparticle separations. There are PE changes with real gases where the particles are more closely packed and to find out why this is so search for the interatomic / intermolecular force curve.
Potential energy of what object are you talking about?
There is a fixed mass of gas. By increasing the volume, the internal energy doesn't change. So does the temperature change? Cos in my understanding, internal energy= internal KE + internal PE. Does increasing the volume increase the PE of the particles? If so, the internal KE should have decreased as the total internal energy remains unchanged?
when one is handling a gas in a container -it has three parameters pressure, volume and temperature and if you are changing two of them the third may be kept constant .
suppose the volume is being increased keeping temperature constant then the behaviour is pressure decreases .if however the volume is being increased keeping pressure constant then the temperature falls /decreases meaning thereby that the internal energy decreases .the role of PE in in internal energy of a gas is minimal as the energy is most of the time kinetic in nature -it has minimal time interacting with each other .
there are ideal gas laws governing the variation of P ,V and T.
Generally, the "potential energy of a system" can be thought of as the "energy of configuration" [ a function of the configuration variables ].
When the configuration changes (e.g. a displacement, a volume, [and in the case of a capacitor, an amount of charge displaced from equilibrium]), that energy generally changes.
Thank you very much:)
  • · Replies 54 ·
  • · Replies 21 ·
