When is g (9.8) negative or positive?
  • Context: High School
  • Thread starter Thread starter paryann
    Negative Positive
The acceleration due to gravity, denoted as g, has a magnitude of 9.8 m/s² and is a vector quantity that always points downward. The designation of g as positive or negative is contingent upon the chosen coordinate system; if upward is defined as positive, then g is negative, and vice versa. Consistency in the application of the coordinate system is crucial for accurate calculations. Users can adopt either convention as long as they maintain clarity in their definitions.
  • Understanding of vector quantities in physics
  • Familiarity with coordinate systems
  • Basic knowledge of acceleration and its units (m/s²)
  • Concept of gravitational force
  • Research the implications of different coordinate systems in physics
  • Explore vector addition and subtraction in mechanics
  • Learn about gravitational force calculations in various contexts
  • Study the effects of acceleration on motion using free-body diagrams
Students of physics, educators teaching mechanics, and anyone interested in understanding the principles of acceleration and gravity in different coordinate systems.
paryann
when is g (9.8) negative or positive?
i thought that g would be positive when its going towards the ground, and negative when it is being thrown in the air or against gravity.
You can do it either way. If you drop a rock into a hole ten meters deep, you could say that the rock experienced positive acceleration in the downwards direction and ended up ten meters more deep; or you could say that the rock experienced negative acceleration in the upwards direction and ended up ten meters less high. The math works out the same either way, as long as you're careful to be consistent about whether negative means up or negative means down.
The acceleration due to gravity is a vector. It has a magnitude of 9.8 m/s², and its direction is downward. Whether or not that is negative or positive depends on your choice of coordinate system. If you had a coordinate system where up is positive then gravity would be negative since its direction is the opposite of your positive direction. If you had a coordinate system where down is positive then gravity would be positive since its direction is the same as your positive direction.
As long as you are careful and consistent you can get the correct answer either way. I tend to choose a positive=up convention.
  • · Replies 22 ·
  • · Replies 20 ·
  • · Replies 18 ·
11K
  • · Replies 21 ·
