When the light enters calcite it is splitting in two rays
  • Context: Graduate
  • Thread starter Thread starter agentas
    Light Rays Splitting
The discussion centers around the behavior of light as it enters calcite, specifically regarding the splitting of light into two rays—ordinary and extraordinary—along with their relationship to the optic axis. Participants explore the definitions and characteristics of these rays, including their polarization and velocity, while referencing various sources for clarification.
  • One participant states that light entering calcite splits into two rays that are perpendicular and polarized to each other, questioning which ray is perpendicular or parallel to the optic axis.
  • Another participant explains that in uniaxial crystals, waves propagating along the 'z' direction are extraordinary, while those in the 'x' and 'y' directions are ordinary, with ordinary waves having a velocity independent of direction.
  • A later reply suggests that the extraordinary wave is parallel to the optical axis and the ordinary wave is perpendicular, challenging the accuracy of Wikipedia's description of birefringence.
  • Another participant defends the Wikipedia entry, noting that it correctly describes the effective refractive indices and the definitions of ordinary and extraordinary rays, while pointing out a potential terminological inconsistency regarding "optical axis" versus "optic axis."
Participants express conflicting views regarding the definitions of ordinary and extraordinary rays in relation to the optic axis, with no consensus reached on the correct interpretation. The discussion remains unresolved with multiple competing perspectives.
Some participants reference different sources, leading to confusion over terminology and definitions. There are also mentions of the properties of positive and negative uniaxial crystals, which may influence the discussion but are not fully explored.
agentas
When the light enters calcite it is splitting in two rays perpendicular polarized to each other ordinary and extraordinary,right?But then which ray is perpendicular to the optic axis and which are parallel.I do not understand this because some books say ordinary wave is perpendicular and extraordinary is parallel,but then wikipedia says oppositively that ordinary wave is perpendicular to optical axis and extraordinaty is parallel to it.Who is the right?Please give me right answer.And also which wave has greater velocity?Thanks
Science news on Phys.org
In uniaxial crystals, there is one special direction along the crystal axis of three- (trigonal), four- (tetragonal) or six-fold (hexagonal) symmetry (usually defined to be the 'z' direction). Then, the full dielectric tensor resolves into two components e_z and e_x = e_y. Biaxial crystals have no crystallographic-equivalent directions and e_x != e_y != e_z.
In uniaxial crystals, waves that propagate in 'z' are extraordinary, while those the propagate in x and y are ordinary- ordinary waves propagate with a velocity independent of direction.
If the crystal is positive uniaxial (quartz), then v_e < v_o, while negative uniaxial crystals (calcite) have v_e > v_o.
I do not really quit understand that you have wrote,but i think i already found the answer and it like this:extraordinary wave will be parallel to the optical axis and ordinary wave will be perpendicular.be aware what is wrong description in wikipedia about birefringence
You mayfind this thread interesting.
http://forum.allaboutcircuits.com/showthread.php?t=53259
I didn't see anything obviously wrong in the Wiki entry. For example, see the table "Effective refractive indices in negative uniaxial materials" and the text "For a given propagation direction, there are generally two perpendicular polarizations for which the medium behaves as if it had a single effective refractive index. In a uniaxial material, rays with these polarizations are called the extraordinary and the ordinary ray (e and o rays), corresponding to the extraordinary and ordinary refractive indices."
My only complaint about the wiki article is that it sometimes uses the term "optical axis" instead of "optic axis"- the "optical" axis refers to the direction of light propagation, and specifically the centerline of a rotationally symmetric optical system. The "optic" axis refers to the crystal orientation of a inhomogeneous optical material.
http://en.wikipedia.org/wiki/Optic_axis_of_a_crystal
  • · Replies 43 ·
  • · Replies 22 ·
14K
