Where Am I Going Wrong with the Secular Determinant in MO Method?
  • Thread starter Thread starter SporadicSmile
    Determinant Method
The discussion revolves around the application of the secular determinant in the context of molecular quantum mechanics, specifically focusing on the algebraic manipulation involved in solving for energy levels.
  • Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants explore the correct formulation of the secular determinant and its implications for finding energy solutions. There are attempts to clarify the steps involved in expanding the determinant and solving the resulting quadratic equation.
Some participants are actively working through their calculations and expressing uncertainty about specific algebraic steps. There is recognition of errors in the application of the quadratic formula, with one participant offering to help identify mistakes in another's work. Multiple interpretations of the determinant's solutions are being discussed.
Participants note that the values of α and β are distinct, which affects the solutions to the quadratic equation. There is an acknowledgment of the potential for algebraic errors and the need for careful review of the steps taken in calculations.
SporadicSmile
Not a problem par se, as much as me failing somewhere in algebra, and i can't find my mistakes.
Trying to work through the secular determinant
[tex] <br /> E_\pm = det\left(<br /> \begin{array}{cc}<br /> \alpha - E & \beta - ES\\<br /> \beta - ES & \alpha - E<br /> \end{array}<br /> \right)<br /> = 0<br /> [/tex]
which gives the answer
[tex] <br /> E_\pm = \frac{\alpha \pm \beta} {1 \pm S}<br /> [/tex]
This multiplies out to give
[tex] <br /> (\alpha - E)^2 - (\beta - ES)^2 = 0<br /> [/tex]
which with rearrangement gives
[tex] <br /> (1 - S^2)E^2 + 2(\beta S - \alpha)E + (\alpha^2 - \beta^2) = 0<br /> [/tex]
this is quadratic in E, so solutions will be given by the usual formula for solving quadratic equations. This is where I seem to fail, rather badly really, and I can't find my error. If someone could point me in the direction of somewhere this has been solved fully, each step so i can find my error, id be very much obliged. If not I can write out my own calculations on here, but that is rather time consuming. But I will if needed.
Thanks
Steve
Are you sure you have the correct determinant equation?
...After a little bit of work, you should find that your equation gives two solutions: [itex]E=0[/itex] and [tex]E=\frac{\alpha+\beta}{1+S}+\frac{\alpha-\beta}{1-S}[/tex]...which is somewhat different from what you claim the answer is supposed to be.
From Atkins 'Molecular Quantum Mechanics' page 254:
The Secular determinant is then
[tex] <br /> <br /> E_\pm = det\left(<br /> \begin{array}{cc}<br /> \alpha - E & \beta - ES\\<br /> \beta - ES & \alpha - E<br /> \end{array}<br /> \right)<br /> = 0<br /> <br /> [/tex]
This equation (a quadratic equation in E when the determinant is expanded) has the solutions
[tex] <br /> <br /> E_\pm = \frac{\alpha \pm \beta} {1 \pm S}<br /> <br /> [/tex]
Perhaps my post also wasn't very clear, the third equation is an expansion of the determinant, just looking over it realized that might not be 100% clear at first glance.
Wouldn't E = 0 only be a solution to the quadratic equation if [tex]\alpha[/tex] = [tex]\beta[/tex], which it does not ([tex]\alpha[/tex] is the coulomb intergral, [tex]\beta[/tex] the resonance integral, although this isn't really important here, I'm more bothered about why I suddenly can't do basic algebra.)
hmmm...yes E=0 isn't a solution...I made an error in my algebra too...after correcting it, I get the desired solution...If you show me your work (a few lines at a time), I can point out where you are going wrong.
Okay i will set out my calculations, might be useful might be i spot my own mistake, or what i need to do.
Solving the quadratic formula:
[tex] <br /> E_\pm = \frac{-b^2 \pm \sqrt{b^2 - 4ac}} {2a}<br /> [/tex]
where, in the case of the equation i have:
[tex] a = (1 - S^2)[/tex]
[tex] b = 2(\beta S - \alpha)[/tex]
[tex] c = (\alpha^2 - \beta^2)[/tex]
working out each part separately (for clarity):
[tex] b^2 = 4(\beta S - \alpha) = 4(\beta^2 E^2 + \alpha^2 - 2\alpha \beta S)[/tex]
[tex] 4ac = 4(1 - S^2)(\alpha^2 - \beta^2)[/tex]
[tex] = 4(\alpha^2 - \beta^2 - S^2 \alpha^2 + S^2 \beta^2)[/tex]
[tex] b^2 - 4ac = 4(\beta^2 - 2\alpha \beta S + S^2 \alpha^2)[/tex]
[tex] = 4(\beta - S \alpha)^2[/tex]
[tex] \sqrt{4(\beta - S \alpha)^2} = 2(\beta - S \alpha)[/tex]
[tex] -b^2 \pm \sqrt{b^2 - 4ac} = 4(-\beta^2 + 2\alpha \beta S - S^2 \alpha^2) \pm 2(\beta - S \alpha)[/tex]
Which is where i seem to lose myself in not being able to simplify any further.
I get the feeling I am missing something trivial, but its one of those things where the longer i stare at it the less i can see it.
You're gunna kick urself when you realize your mistake...take a deep a breath and remember to smile...are you ready?...The quadratic formula is [tex]E_\pm = \frac{-b \pm \sqrt{b^2 - 4ac}} {2a}[/tex] not [tex]E_\pm = \frac{-b^2 \pm \sqrt{b^2 - 4ac}} {2a}[/tex]...i.e. the -b isn't squared.:smile:
Well, when i vote for the most embarasing moment of the year i think i know what i will pick..
Goddamit!
Well, at least i can do algebra, i just can't remeber formulae! that's almost something i think
Cheers =>
