Where can I find a digital counter for turns?
  • Thread starter Thread starter kolleamm
    Counter Digital
The discussion centers on finding a suitable digital counter for a winding machine that counts turns and can subtract backwards. Participants suggest using a second-hand odometer counter from a scrap car, which can be modified by removing the worm reduction and driving the counter directly. Additionally, optical position encoders are recommended for their affordability and ease of integration, especially for those with soldering skills. Other creative solutions include modifying calculators or cassette tape counters to serve as turn counters.
  • Understanding of optical position encoders
  • Basic soldering skills for circuit assembly
  • Familiarity with odometer mechanics
  • Knowledge of modifying electronic devices
  • Research how to integrate optical position encoders into mechanical systems
  • Learn about modifying odometers for custom applications
  • Explore DIY electronics projects involving calculators and counters
  • Investigate the specifications and wiring of second-hand automotive components
Engineers, hobbyists, and DIY enthusiasts looking to implement custom counting solutions in mechanical applications, particularly those working with winding machines or similar devices.
kolleamm
I have a winding machine that needs a counter to count it's turns, subtract backwards also. I did a search but most results were fairly expensive and bulky.
Any help is appreciated.
Thanks in advance
kolleamm said:
fairly expensive
How large a number is "fairly?"
The machines are from $50 and up. Money isn't a huge problem it's just the size.
Why not use a second hand odometer counter out of a scrap car instrument panel.
Remove the worm reduction and drive the end counter directly.
If you use a trip counter you will be able to reset it to zero.
Optical position encoders are very cheap and so is the driving circuitry (if you are hand with a soldering iron).
Thank you for the suggestions everyone, I will try out your ideas.
  • · Replies 26 ·
  • · Replies 49 ·
