Where Does the Ball Become Airborne?
9 replies · 3K views · last reply
Matt Raj
There is an object at the top of a frictionless hemispherical hill with radius R. t time t=0, it is given a small impulse so that it starts sliding down the hill. Find the height from the ground where the ball becomes airborne. Express your answer in terms of R.
a_c=v^2/r
I first attempted setting mv^2/r equal to the force of gravity and the normal force which keep it on its circular path, but I couldn't get a proper equation with it.
Hello Matt, :welcome:
Well, post what you did get !
The centrifugal force and gravity don't point in the same directions. You'll need the components orthogonal to the surface.
Can you find v as function of the height or the angle of the object on the hemisphere?
Using the centripetal acceleration, I found that mv^2/R=mg/cos(theta), so v^2=Rg/cos(theta). Furthermore, I used conservation of energy to find that mgR=mgRcos(theta)+1/2(mv^2). I tried solving this system of equations but I got cos^2(theta)-cos^3(theta)=Rg and couldn't go anywhere after that.
i believe this expression is not quite right the height difference between initial position and final position is what you need r/cos theta as far as i can see doesn't represent any height
there is also normal force and what can you say about normal force when it just becomes airborne
Did you make a clear sketch showing what coordinates you use ?
Good so far. Something went wrong later because this should lead to a quadratic equation.
Edit: ehild is right, there is a mistake.
Are you sure?
Sorry, I divided by cos(theta) instead of multiplying. The equations should be mv^2/R=mg*cos(theta) and mgR=mgRcos(theta)+1/2(mv^2). Solving this gave me 2/3=cos(theta), so the height that the ball leaves the hill is Rcos(theta)=2R/3.
Matt Raj said:
Rcos(theta)=2R/3
You can simplify that further and solve for h, surely?
