Where does the missing energy go in an inelastic collision?
  • Context: Undergrad
  • Thread starter Thread starter Lukeblackhill
    Energy
The discussion centers on the energy transformation during an inelastic collision, specifically when two equal masses collide and stick together. It is established that, according to the conservation of momentum, the final velocity of the combined mass is half of the initial velocity of the moving mass. The kinetic energy after the collision is half of that before the collision, with the missing energy primarily dissipated as heat, sound, and deformation work. The process may also involve damped oscillations, indicating energy dissipation over time.
  • Understanding of conservation of momentum
  • Basic knowledge of kinetic energy calculations
  • Familiarity with inelastic collisions
  • Concept of energy dissipation in physical systems
  • Research the principles of conservation of momentum in two-body collisions
  • Study the equations for kinetic energy before and after inelastic collisions
  • Explore the mechanics of material deformation during collisions
  • Investigate the effects of damped oscillations in energy dissipation
Physics students, educators, and professionals in mechanical engineering or materials science who are interested in understanding energy transformations in collisions.
Lukeblackhill
Morning,
I was thinking about a simple example of inelastic collision: A ball of mass m1, moving with a certain velocity v1, collides and sticks with another mass m2, at rest. The whole system (m1 + m2) will then move with a certain speed v3.
If we take m1=m2, so that after the collision we have a single mass of 2m1 mass, by the conservation of momentum, v3 = v1/2. If we work out the kinetic energy of the system before and after the collision, we have K(after) = K(before)/2.
The question is...where does the other half of kinetic energy goes to? In such a collision, must we necessarily expect losses in terms of heat and sound, or can we find that other half transformed in some sort of "gluing energy"?
Cheers,
Luke.
'All' the missing energy will go into the deformation process, heat and sound. It can require a lot of work to deform materials. There will often be some damped oscillation during the process, in which the energy is dissipated over a significant length of time.
Thank you, @sophiecentaur.
10K
