Which ball travels further, up a ramp or thrown in the air
  • Thread starter Thread starter Alexstrasza
    Air Ball Ramp
The discussion centers on the comparison of two identical balls: one thrown up a frictionless ramp and the other thrown vertically into the air, both at the same initial velocity. The consensus is that the ball on the ramp travels further due to the ramp's support, which allows for energy conservation and conversion into height. The mechanical energy of the ball on the ramp is conserved as there is no friction, and the normal force does not perform work. The "Range" equation is highlighted as a key tool for calculating the distance traveled by the ball thrown in the air.
  • Understanding of Newton's laws of motion (F=ma)
  • Knowledge of kinetic and potential energy equations (K(e)=mv^2/2, P(e)=m*g*h)
  • Familiarity with the concept of mechanical energy conservation
  • Ability to apply the Range equation for projectile motion
  • Study the principles of energy conservation in mechanical systems
  • Learn how to apply the Range equation in different projectile scenarios
  • Explore the effects of friction on energy transfer in motion
  • Investigate the role of normal force in energy conservation on inclined planes
Physics students, educators, and anyone interested in understanding the dynamics of motion on inclined planes versus projectile motion.
Alexstrasza
Two identical balls, one is thrown at angle α up a frictionless surface, the other one is thrown at the same angle up in the air.
Both have the same initial velocity.
A. Which one travels further? Explain.
B. Is the mechanical energy of the first ball conserved? Explain.
F=ma
Momentum... p=m*v
W=Fa
[/B]
A. I am having trouble with this one.
I tried to use v(f)=v(i)+2ax but then it is the same equation for both the balls. That can't be right?
I think that the ball in the air would travel the shorter distance, because it doesn't have the support of the ramp.
B. The energy of the first ball is conserved, because there is no friction and the only force except gravity working on that ball is N, which doesn't do work because it's perpendicular.
What are the accelerations for the two balls? Are they the same?
What is x, and how does that equation work if you have to consider two dimensions?
There is also a different effect in the opposite direction.
Is it really perpendicular?
What exactly counts as mechanical energy?
I'm not sure what is meant by "travel further". Horizontal distance? Height?
The "Range" equation will quickly give you the distance the ball in air will travel.
Now if the initial kinetic energy is converted to potential energy,
how far can the ball travel on the incline?
Thanks for the replies everyone. Sorry for late update.
The question was asking to find which ball will reach the maximum height. I tried to solve using energy conservation but then it gives me the same solution for both.
Isn't N always perpendicular to the surface? Energy = initial velocity squared x mass / 2 and energy is conserved.
That is what I am confused about, what is the difference between how far the ball travels up an incline vs. at an angle in the air. I am pretty sure that the incline "helps" the ball but not sure how to express it.
Ah, now the question makes sense.
Describe what you did for each. They are not quite the same.
Hint: What's the speed of each ball when it reaches maximum height?
As Doc Al implied, consider the "total" energy at the top of the trajectory for each case.
Energy is not the only conserved quantity that is relevant for the freely falling ball.
The force from the surface is, the force from gravity is not.
No. It will not give distance traveled.
It will only give the displacement.
Quite so, the normal force does no work. But forces acting on an object can transfer the energy of an object from one form to another without doing any net work. E.g. when a ball rolls down a slope, the friction transfers energy into rotational KE.
This is the way that the ramp 'helps' the ball go higher.
Frictionless surface.
Yes, I understand that. I was just using rolling down a frictional slope as an example of how a force that does no work can transfer energy from one mode to another. The same happens here, but not in respect of rotation.
  • · Replies 32 ·
  • · Replies 19 ·
  • · Replies 29 ·
