Which best metal cutting tool to do this job?
  • Context: Wood/Glass/Metal
  • Thread starter Thread starter tirelessphoenix
    Cutting Metal
The discussion revolves around the best metal cutting tool for making a precise straight cut in a hollow square metal piece. Participants explore various tools and techniques suitable for this task, considering factors such as kerf width, precision, and the nature of the material being cut.
  • Experimental/applied
  • Some participants suggest using a Dremel tool with a cutting disk, noting it may be manually intensive and not yield perfectly straight cuts.
  • Others agree on the Dremel's utility, recommending taking time and using additional tools like rotary files for cleanup.
  • One participant mentions that a steel cutting blade in a table saw could be effective if a 2.5 mm kerf is acceptable, sharing personal experience with cutting steel.
  • Concerns are raised about the specific cutting requirements, as the original poster seeks a plunge cut in a hollow section, which may not be feasible with all suggested methods.
  • Another participant proposes using a chain drill followed by filing, acknowledging the tedious nature of the task due to the limitations of tube steel.
  • One participant emphasizes the importance of securely clamping the workpiece to prevent wandering cuts, expressing skepticism about freehand cutting methods shown in videos.
Participants generally agree on the potential effectiveness of the Dremel tool and table saw for cutting metal, but there is no consensus on the best method for achieving the desired cut in the specific hollow square piece. Multiple competing views and techniques remain under consideration.
The discussion highlights the need for additional information, such as dimensions and specific requirements of the cut, which could influence the choice of tools and methods. There is also an acknowledgment of the importance of workpiece stability during cutting.
tirelessphoenix
TL;DR
I want to do a straight metal cutting
I want to do a straight metal cutting, leaving a not too wide line whole in the middle (the filled white part) as seen in the picture. Does anyone know which tool would do this best?
Second the Dremel call. Take your time, let the speed of the tool do the work. Use either a rotary file on the Dremel and/or needle file(s) to clean up.
Unless you have access to a milling machine, the Dremel will be pretty much the fastest possible solution.
If you are cutting steel, and can tolerate a 2.5 mm kerf, a steel cutting blade in a table saw works very well. This particular blade has cut over 30 lineal feet of steel in various thicknesses up to about 3/8" in my table saw. Goggles for eye protection are required because hot chips fly. I clean the sawdust from inside my table saw before using because I do not want the hot chips starting a fire. Hearing protection also required because it's noisy.
Great tip! I don't know if I would have thought of that ahead of time (versus when I was reaching for the fire extinguisher)...
The issue I see is that he’s looking at a plunge cut in the middle of the piece, not a cut that can be made from the end of the piece. It also seems to be a tube/box section, not plate, and it’s unclear if the cut is intended for both sides.
@tirelessphoenix , can you show us another view of the piece that you wish to cut this slot into? Some dimensions will be quite helpful as well.
here it is. its a hollow square, not that thick
Chain drill then file. This will be tedious because the tube steel limits the file stroke. Take your time and drill carefully to avoid a wiggly slot. A dremel tool is faster than filing but it also makes faster mistakes if you're not well practiced.
Maybe there is a "maker" space nearby? They could mill your slot in 10 minutes.
I may be preaching to the converted but I have to mention the importance of firm workpiece holding (clamping) if you want to avoid 'wandering' of the cut and juddering. I really don't believe the YouTube videos where the guy does everything freehand and gets a perfect line and finish. I always suspect that there's a milling machine lurking somewhere in behind.
High speed and a fine tool will improve chances of a convincing finish.
  • · Replies 23 ·
  • · Replies 42 ·
