Which Bulb Lasts Longer: Brand A or Brand B?
  • Thread starter Thread starter rclakmal
    Probability
The discussion focuses on calculating the probability that a Brand A bulb lasts longer than a Brand B bulb, given that the lifetimes of both brands are normally distributed. Brand A has a mean lifetime of 1010 hours with a standard deviation of 5 hours, while Brand B has a mean of 1020 hours and a standard deviation of 10 hours. The solution involves determining the distribution of the difference in lifetimes (C = A - B) and calculating the probability that C is greater than zero. The final calculated probability is 0.18555.
  • Understanding of normal distribution and Z-scores
  • Knowledge of expectation and standard deviation in statistics
  • Familiarity with probability calculations involving independent variables
  • Experience using statistical tables or calculators for probability values
  • Learn about the properties of the normal distribution and its applications
  • Study how to calculate probabilities for the difference of two independent normal variables
  • Explore the use of Z-scores in hypothesis testing
  • Investigate statistical software tools for performing probability calculations
This discussion is beneficial for students in statistics, data analysts, and anyone interested in understanding probability calculations involving normally distributed variables.
rclakmal
The life time of electric lights brand A and B independent and normally distributed .For brand A bulbs the mean and standard deviation of the life time are 1010 hours and 5 hours respectively .For brand B those values are 1020 and 10 hours calculate the probability that a Brand A bulb will have a longer life than brand B
If this question was asking about a probability of brand A to have a life time of a particular value (as an example 1000 hours ) then i know how to calculate the probability by converting this distribution to a Standard Normal Distribution by using Z score .then You can easily obtain the value by given tables or by a calculator .That can be also done to brand B.
But the problem is i don't how to connect these two distribution >please someone help on this question .
When you have two normally distributed variables X and Y you can also form
- a negative -X, with expectation value E(-X) = -E(X) and standarddeviation S(-X) = S(X)
- the sum X + Y, with expectation value E(X + Y) = E(X) + E(Y) and standard deviation S(X + Y) = sqrt( S(X)^2 + S(Y)^2 )
You can use these to see that the difference of the life times is also normally distributed.
then i should write E(A-B) and S(A-B) as you have mentioned i can obtain values for them.
Then i should consider it as an individual probability .Lets name it as C( C=A-B).
then by tables or by calculator i should obtain a probability value where C>0.
Then i obtain an answer as 0.18555 .Could you please check it and tell me .that would be a great help
