Which Direction Does the Force on the Electrons Act in a TV Tube?
The discussion revolves around the forces acting on electrons in a television tube, specifically in the context of the Earth's magnetic field. The problem involves determining the direction of the force on the electrons, calculating acceleration due to the magnetic field, and understanding the implications of the Earth's magnetic field's inclination.
  • Participants explore the application of the right-hand rule, particularly considering the negative charge of electrons. There are attempts to clarify the calculations for force and acceleration, with some participants expressing confusion about the angles involved and the correct application of formulas.
Some participants have provided insights into the application of the right-hand rule and the significance of the negative charge of electrons. There is ongoing exploration of the angles related to the Earth's magnetic field and the velocity of the electrons, with various interpretations being discussed. Participants are encouraged to articulate their reasoning and clarify their calculations.
There is mention of potential confusion regarding the inclination of the Earth's magnetic field and its relationship to the angles used in calculations. Participants are also considering the implications of rounding errors and the accuracy of their arithmetic in the context of computer-graded responses.
mshiddensecret
The electrons in the beam of a television tube have an energy of 15 keV. The tube is oriented so that the electrons move horizontally from south to north. The vertical component of the Earth's magnetic field at the location of the television has a magnitude of 57.0 μT and is pointing down.
a) In which direction does the force on the electrons act (enter N for north, S for South, E for East, or W for West)?
Neglect a possible horizontal component of the magnetic field.
b) What is the magnitude of the acceleration due to the vertical component of the Earth's magnetic field of an electron in the beam?
c) If the inclination of the Earth's magnetic field near the TV is 66deg, calculate the magnitude of the force on the electrons due to the horizontal component of the Earth's magnetic field.
B = qv x B
a) according to the right hand rule, it should be W. But apparently i am wrong.
b) I got the answer which is 7.26 x 10^14 m/s^2
and also the F = 6.62 x 10^-16 N
c) it should be 6.62x10^-16 x sin 66 right? I didn't get it right.
(a) how are you applying the right-hand rule?
Did you account for electrons being negatively charged?
(b) are you saying you got the right answer?
(c) so what did you get and how did you get it?
A) I found out. It is east. B) I got the correct answer
C) I multiply the force which I got before dividing it by the mass to get the acceleration. And multiply by sin 66 which is incorrect. I am lost
For "a)", how do you know you are wrong?
For "b)", can you tell us what working did you do to reach the answer for acceleration and force?
ignore my previous post
... yes, but how did you apply the right-hand rule so that you got "west" ... the RHR should give you east.
Basically it sounds like you did the right-hand rule correctly for the cross product, but neglected that the electron is negative.
The equation is ##\vec F=q \vec v \times \vec B## and in your case, ##q=-e##. That minus sign reverses the direction of the resultant.
Well done. I take it you used ##F_B=qvB##?
So you used: ##F_C = qvB\sin\theta = F_B \sin\theta## where ##F_B## is the force from part (B)?
If this answer is wrong then you probably have the wrong value for the angle between ##\vec v## and ##\vec B.##.
If the answer is being marked by a computer, then you also need to check for rounding errors and the correct sig fig. Stuff like that.
What do you mean by the wrong value for the angle? 66?
6.05e-16 N was my answer for C.
The problem statement says that the inclination of the field is 66deg.
It does not say that this is the same as the angle between the velocity and field vectors - your result would imply that it isn't.
So what is it an angle to?
It's always possible that the computer answer is wrong - it happens.
It could also be a mistake in your arithmetic ... I don't check arithmetic.
Bare numbers don't mean anything. What counts is how you got them - by what reasoning.
I have no idea at this point.
Well if 66deg is not the angle of the field to the velocity, what could it be to?
Have you tried googling for "inclination of Earth's magnetic field" to find out what most people mean by that?
Have you checked your arithmetic?
Have you checked for rounding errors?
Have you checked you have the right decimal places?
"no idea" is not acceptable - you have the means to get ideas: use them.
24?
24?
Bare numbers have no meaning.
What do you suggest?
Try saying how you arrived at the number and what it is for.
re. last line post #9
Well the formula is qv x b. So by sin 66, it makes it orthogonal to it.
So "24" was intended to be an angle to use for "theta" in the formula.
That would be 24 degrees ... the reasoning is that if "inclination" means "angle to the vertical" then the angle to the velocity vector (which is horizontal) will be 90-minus-inclination or 90-66=34 degrees
See how that is clearer than just writing a number?
Have you tried that angle in the formula to see if it gives the right answer?
Note - I still don't see how you got 24deg.
... "by sin66, it makes it orthogonal to it" is meaningless. What are the "it"s in that sentence?
Did you try any of the other suggestions in post #11?
OK - now I think I've got a handle on how you talk... I think we are getting further off track.
Back up: what is the vertical component of the Earth's magnetic field?
If the angle to the horizontal is 66deg, then what is the total field?
i.e. what is the relationship between the total field and the vertical component of the field?
Vertical is the one I found. So, if I cos 66, I should find the total field.
9K
