Which method of integration for sin^2(x) dx
  • Context: Undergrad
  • Thread starter Thread starter Adyssa
    Dx Integration Method
The integral of sin²(x) can be effectively solved using the double angle identity sin²(x) = (1 - cos(2x))/2. This method simplifies the integration process significantly. The final result of the integral ∫sin²(x) dx is x/2 - (1/4)sin(2x) + C, verified through differentiation. Integration by parts is also a valid approach, but the double angle identity provides a more straightforward solution.
  • Understanding of trigonometric identities, specifically the double angle formulas.
  • Familiarity with basic integration techniques, including substitution and integration by parts.
  • Knowledge of differentiation to verify integration results.
  • Proficiency in handling integrals involving trigonometric functions.
  • Study the derivation and application of the double angle identities in trigonometry.
  • Learn the method of integration by parts in detail, including its formula and applications.
  • Practice solving integrals involving trigonometric functions to reinforce understanding.
  • Explore advanced integration techniques, such as integration by substitution and reduction formulas.
Students in calculus, mathematics educators, and anyone looking to enhance their skills in solving trigonometric integrals.
Adyssa
During maths class last semester this integral came up in the course of discussion and my lecturer gave a quick outline of how to solve it but I didn't grasp it at the time and we moved on. I'd like to know how to do it though! The integral is:
\int sin^{2}(x)
The next step was:
\int sin(x).(-cos(x)')
where -cos(x)' denotes the derivative of -cos(x) and the implication was that sin^{2}(x) is the result of applying the chain rule to whatever compound function it is the derivative of. I can't remember the result but further steps were skipped and he jumped straight to the answer at this point.
I'm not sure how to proceed here, because the chain rule implies that \frac{dy}{dx} f(g(x)) = f'(g(x) . g'(x), and in my example g(x) = x and g'(x) = 1 which doesn't help me end up with sin(x) as required.
Could anyone poke me in the right direction to solve this? =)
I'd forget the chain rule and try to re-write \sin^2x as something I could integrate, if I were you. It might be possible by parts, too, but I haven't actually tried that so I wouldn't swear to it.
The method I was taught was to use the double angle formula for cosine.
I really have no idea what your teacher is trying to do.
You don't want the chain rule. You want the product rule, the integration equivalent of which is integration by parts.
Before nudging you in the right direction, there is a much easier way to find \int sin^2x\,dx. Use the identity \sin^2x = (\frac{1-\cos(2x)} 2. The right hand side is easy to integrate.
The product rule is (f(x)g(x))' = f'(x)g(x) + f(x)g'(x). Transforming to integration,\int (f(x)g(x))' dx = f(x)g(x) = \int f'(x)g(x)dx + \int f(x)g'(x)dx
Note that this is integration by parts, just written a bit differently. You are using f(x)=\sin x and g(x)=-\cos x. Plug these in. You'll eventually need a different trig identity, \sin^2x + \cos^2x = 1, to finish it off.
Thanks for the replies. I'm really awful at remembering trig identities (and remembering in general =S), I had a large gap between high school and university maths, so I have to re-learn a lot of the basics as I go along.
I solved it by using the double angle identity sin^{2}x = \frac{1 - cos(2x)}{2} and integration by substitution - u = 2x, du = 2dx, dx = \frac{1}{2}du, and my result was \frac{x}{2} - \frac{1}{4}sin(2x). I took the derivative to check my answer and it worked, so that's great!
I'm going to have a go at the integration by parts method now.
Adyssa, I had a typo (matho) in my previous post.
It is always a good idea to double check your work. Good job!
You can try another technique...
let
I=∫sin^{2}xdx ---------(i)
or I=∫dx-∫cos^{2}xdx
or I=x-∫cos^{2}xdx +c_{1} -------(ii)
Adding (i) and (ii),
2I=x-∫[cos^{2}x-sin^{2}x]dx +c_{1}
2I=x-∫cos2xdx +c_{1}
2I=x-1/2 sin2x +c
I=x/2 - 1/4 sin2x+c
